10-23-2017, 08:59 PM | #1 |
Drives: 2015 1LE, 2SS, Bright Yellow Join Date: Mar 2016
G3 Supercar compared to the G2?
Hi Rudy, I saw a fellow member with a Gen 5 1LE was running (and liked) the new G3 version of the Goodyear Supercars. The Tire Rack website shows the 285-30-20 G3 is taller than the 285-35-20 G2. It also has a lesser load rating.
I've not been able to verify any of this on the Goodyear website, but have no reason to doubt what I see on Tire Rack's website. My questions are; 1. How can a smaller 30 series/ratio tire be larger in diameter than a 35 when their tread width is the same? and, 2. The load rating on the G3 looks suitable for a Gen 5 1LE. Is it? It's almost time for new tires, Thank you |
10-25-2017, 12:20 PM | #2 |
Drives: 2012 RS/2SS, 69 ProStreet Camaro Join Date: Oct 2011
Something it not right. The 285/30/20 would be shorter by just over an inch in diameter compared to a 285/35/20, not taller.
10-25-2017, 01:53 PM | #3 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
PROZ11 is correct, they compute to be ~ 1 inch shorter diameter
https://www.tacomaworld.com/tirecalc...0r20-285-35r20
10-25-2017, 10:20 PM | #4 |
Yes, and that is my point.
https://www.tirerack.com/tires/tires...F1S3&tab=Sizes
G3 shows 28.8 inch diameter and shows tread width to be ,7 inches wider. https://www.tirerack.com/tires/tires...2LV2&tab=Sizes G2 shows 27.9 inch diameter. This does not make sense to me. I've tried to get info from Goodyear's website, but that is a very poorly designed website. One of the worst I've seen. |
