02-09-2018, 03:38 PM | #1 |
Drives: 2015 1LE, 2SS, Bright Yellow Join Date: Mar 2016
Strut dimensions for camber plates
Hello everyone, I was looking to have Vorschlag make a set of camber plates for my car. They have dimensions for the SS and 1LE, but mine is a 1LE with the full Z/28 Multimatic suspension and they don't have those dimensions on file.
I've got the car up on a lift but of course don't have a deep 24mm socket handy. So, figured I'd post this question and see if anyone has the info handy. Attached is a file from Vorschlag for the dimensions. Thanks, |
02-09-2018, 06:09 PM | #2 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Hmmm, I believe the DSSV dimensions should be the same as the 1LE, since the OE top mount is the same. I also have the DSSVs.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
02-09-2018, 11:22 PM | #3 |
Don't have my micrometer with me so just used my tape measure but other than OAL, the dimensions look the same to me.
The nut on top is the same pitch and thread, which from a manufacturers perspective makes sense to keep parts common. |
02-10-2018, 05:36 AM | #4 |
Drives: . Join Date: Jun 2016
I've been thinking about trying to get hold of a ZL1 1LE 6th gen DSSV front strut to take a look at and do a comparison.
The bottom end mount to the upright looks very similar. The rollbar droplink attachments could be sorted. It's just whether it would be possible to swap some components around at the top end to make it fit, and whether the overall length and springrate are close to appropriate. The body is alloy so it would be a significant weight saving. |
02-10-2018, 11:09 AM | #5 | |
Drives: Z/28 Join Date: Jan 2015
Re: the Z/28 springs - they are the same dia as the 1LE springs and use the same perch |
02-10-2018, 11:19 AM | #6 | |
Do the Vorschlag plates add height?
02-10-2018, 11:21 AM | #7 | |
Aris, you still liking the DSE kit on your Z?
