Old 02-25-2020, 05:46 AM   #1
eLeSthree
Drives: 2011 Camaro SS 6sp
Who would you chose to build your 1200hp+ Shortblock?
I've already worked up a nice quote with TSP that I'm fairly happy with.
New LY6 block
CP pistons 4.030 (.200)pins (or.230?)
TSP I beams
TSP Forged Crank (3.622)
ARP mains
balanced, bearings, rings, shipped to my house with 12 qts break in oil.
$5224.
The reason I've gone with Iron, is due to strength. It seems its becoming more popular that guys over 1100whp are cracking the stock sleeves in the ls3. Even the standard stroke, stock sleeve ls3 short blocks cost a good $1600 more, and aren't as strong as iron. Thoughts?
Would you change anything in that build list?
I think that should take some good abuse. However I was concerned with the Iron weight penalty.
While the car is down I will be stripping it down as much as I can to shed weight. I'm sure I can get 75#s off of it. Maybe not off the nose, but..
I"ve checked with Thompson, LME, couple local guys. No one can seem to beat their price.
Who would you chose to build your short block.
FYI, I have assembled 3 motors myself over the years, and all of them, are still running great today. However not at this power level. Not sure plastiguage is a good idea this time around. Then again, I trust NO ONE.
2011 Camaro SS M6
DSX Tuning
HP Tuners Pro
ESS Tuning G3X Blower 913whp/787tq@6400
JRE Tuned
eLeSthree is offline   Reply With Quote
Old 02-25-2020, 05:53 AM   #2
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
Build
Andy Jensen engine technologies in pa.
Or tkm Motorsports in nc
2010 camaro twin turbo 8.60 @ 157 full weight 4200
1fast is offline   Reply With Quote
Old 02-25-2020, 06:25 AM   #3
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
NASA
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 02-25-2020, 07:52 AM   #4
eLeSthree
I can't say I've heard of them, not to say they aren't good. Was looking for a larger company that can afford to right their wrongs if they arise.
Originally Posted by hunter1660 View Post
NASA
Out. Of. Budget.
2011 Camaro SS M6
DSX Tuning
HP Tuners Pro
JRE Tuned
Old 02-25-2020, 08:27 AM   #5
jnmn
2&thahit
jnmn's Avatar
Drives: a black SS on sunny days :)
also a plug for TKM. They are top notch and will build anything- LS, Hemi... you name it
jnmn is offline   Reply With Quote
Old 02-25-2020, 08:39 AM   #6
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Wegnerautomotive.com
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
Clarkstar is online now   Reply With Quote
Old 02-25-2020, 09:10 AM   #7
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
We have a couple proven short blocks we have been doing lately. We'll have then listed on our site soon. Forged iron block 6.0, a forged LS3 and we'll have a LS3 stroker available soon as well. Quality builds that are priced to move. Currently we've just been doing them on local builds but we will be shipping them soon.
We carry & install all the hottest brands for your 5th/6gen Camaro. Get awesome deals & install rates! Call or Pm us for your CAMARO5/CAMARO6 discount. 224-63-JUICE or INFO@JUICEDMOTORSPORTS.COM ST CHARLES IL
Juiced1 is offline   Reply With Quote
Old 02-25-2020, 09:36 AM   #8
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
If you are comfortable with assembling engines - I would tear down the assembly and check every measurement twice then re-assemble. Maybe a good micro polish on the crank and an alum barbel. ARP studs - but you are prob already doing that. Studs on the mains can change the clearance. Maybe talk to TSP and assemble the clearances to run 10-40 oil.
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 02-25-2020, 10:03 AM   #9
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
We could come close to an iron block build like this, but at 1200+hp I would definitely suggest paying to go with proven components such as Callies Ultra Rods / Callies Dragonslayer / Magnum crank, etc.
Katech_Zach is offline   Reply With Quote
Old 02-25-2020, 10:38 AM   #10
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
TSP gave you a pretty sharp price, I doubt you will be able to do better for the money.
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 02-25-2020, 11:39 AM   #11
eLeSthree
Thats how I feel right now. I’m over building it to support 1050-1100. But they rate it to 1300. Of course there are no guarantees.
Thompson is also running a nice sale on their Dart SHP. Does anyone know how it compares to the ly6. Weight? Strength? Fitment? Does it need special covers and stuff?
2011 Camaro SS M6
DSX Tuning
HP Tuners Pro
JRE Tuned
Old 02-25-2020, 11:48 AM   #12
racesloth
Dan
Dart SHP has different oiling - priority mains. Longer and thicker cylinders for stroker combos. Thicker deck. Better bay to bay breathing and better cooling around the outboard side of the cylinders - does away with cross bolted mains. Will easily handle 1500-1800 hp. If you are going to stretch to Dart go with 4.125 and stock stroke (388) or 4" stroke (427). Although, Thompson will prob steer you to 388 as that combo seems to just work better. The 4.125 bore will better unshroud the valves. Uses all stock covers etc etc... weight should be about the same.
Dan
2010 IOM SS
Old 02-25-2020, 11:58 AM   #13
eLeSthree
Double post
2011 Camaro SS M6
DSX Tuning
HP Tuners Pro
JRE Tuned
Old 02-25-2020, 12:02 PM   #14
eLeSthree
We’re talking about shp. Not LS next shp, right?
What about fitment, covers, heads. Is it 6 bolt?
2011 Camaro SS M6
DSX Tuning
HP Tuners Pro
JRE Tuned
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
