08-17-2018, 11:59 AM | #1 |
Drives: 1993 z28/2010 2SS Join Date: Aug 2015
failed smog :(
so i did the complete exhaust, i have texas speed long tubes going into a borla atak catback. I did the install a good 2 months ago and then i did the SCT tune a few days later. I deleted the rear o2s and havent had a check engine light since then. i only work 4 miles away but ive had to put a couple hundred miles on it since then. The test results said "OBD EVAP" and "OXY SNSR" N for result and Not Completed under additional information. everything went smooth until the print out, i thought as long as it passed visual and the engine light wasnt on it would pass. Can it see that the rear o2s were turned off/deleted ?
08-17-2018, 12:12 PM | #2 |
oh i think i messed up because my car wasnt warmed up enough
08-17-2018, 01:09 PM | #3 |
Ok that wasn’t it, I just drove a good 10 miles and it’s plenty warmed up but the guy said it has nothing to do with temperature and that someone has been working on the car, and I’m like trust me I’d know it’s my car and I’m the one who works on it. Then told me the engine light is probably going to come on again 🙄. So I don’t know what it is
08-17-2018, 01:31 PM | #4 |
Drives: 2010 Camaro 1SS Join Date: Nov 2015
EVAP is related to the gas canister isn't it?
08-17-2018, 01:56 PM | #5 |
Well it’s acting like the computer was reset recently/battery disconnected but it hasn’t. Basically it’s saying the car hasn’t gone through a driving cycle but it has
08-17-2018, 02:03 PM | #6 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
If you flashed it recently, or cleared the codes, it can take up to 500 miles for the computer to flag the "ready" status.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
08-17-2018, 02:09 PM | #7 |
Oh wow didn’t know that, yeah I probably only put a good 200 miles on it
08-17-2018, 02:30 PM | #8 | |
Captain Gingerbeard
Yep. Keep going without plugging anything into the OBD port about another 300 miles.
08-17-2018, 03:06 PM | #9 |
'It's an experiment'
Did you tune out the rear 02 sensors when the long tube were installed?
EVAP takes forever... This is what I had to do for the EVAP: https://www.camaro5.com/forums/showp...&postcount=627 -Don
747 RWHP 794 RWTQ
08-17-2018, 03:10 PM | #10 |
Yeah I did tune them out, didn’t know there was a whole procedure for the reset. Thought you just had to do a few driving cycles
08-18-2018, 12:00 PM | #11 |
Does anyone know if turning off the rear o2s cause it to be not ready ? Has anyone passed smog with long tubes ?
08-18-2018, 05:10 PM | #12 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
I just had my longtubes put in in April....car was not driven all winter. Didn't put many miles on it at all before doing my emissions on May 6. Zero issues. Im not sure if the should be turned off. Shouldnt they be set to say "ready" ? I could be wrong .
08-18-2018, 05:11 PM | #13 |
08-18-2018, 05:40 PM | #14 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
When the car is tuned some tuners make the mistake of turning the monitors off.
This will cause you to fail the OBD2 plug in test. The driving cycle to reset the computer for a 5th Gen is bizarre my friend sells used cars and he said you need so many miles at certain speeds.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
