Old 05-19-2020, 11:26 AM   #1
Leonardbb
Drives: White ss
Offset and wheel size
wheel guys I have a question for you. What would be the difference between me having a 11” wheel with +11mm offset vs having a 9” wheel with +15 offset?
Leonardbb is offline   Reply With Quote
Old 05-19-2020, 07:07 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
https://www.willtheyfit.com/index.ph...h=9&offset2=15
9" wheel is 21.4mm further from suspension (inside) and 29.4mm further from the fender (outside).
KillboyPowerhead is offline   Reply With Quote
