05-17-2018, 02:59 PM | #1 |
Why do I need a Fuel pump voltage booster
www.jannettyracing.com
10-10-2018, 10:20 PM | #2 |
Drives: 2013 Camaro ZL1 & 1979 10.5 Camaro Join Date: Jul 2016
Is this the case on stock applications as well?
10-11-2018, 08:21 AM | #3 |
With less fuel demand of a completely stock car it is not a problem it is when we start on the modification path that we have to address the fuel supply.
Ted.
11-16-2018, 06:58 PM | #4 |
Drives: 2013 zl1 Join Date: Aug 2017
Ted do we see this issue on a zl1? I know the charging system reduces output depending on battery state and load demand. Someone informed me on his zl1 fuel pressure drop with the same twin dw300 and problem was fpcm over heating from too much current draw and would reduce output to pumps in order to cool itself down. He informed me about a pm3 which is a driver that take the load of the pumps and mimics the pwm from the fpcm so fpcm stays cool, and is able to maintain steady output bc it no longer carries the load, just sends signal. I obtained one and will install over winter. We will so how fuel pressure stays with it installed. He said it solved alot of issues for him. Also is able to run e85 and put down over 800+ to the wheels since adding this. Your my tuner btw Michael Asher.
Sent from my HTC 10 using Tapatalk |
11-18-2018, 11:09 AM | #5 | |
Have not seen the PM3 would like to see more info on it. Ted.
11-18-2018, 03:07 PM | #6 | |
11-19-2018, 07:59 AM | #7 | |
So if you wanted to install Walbro pumps in you stock basket and retain the factory fuel pump control module this would allow that. Basically it takes the PWM signal from the FPCM and converts it back to a 12 volt signal. Ted.
11-19-2018, 09:11 AM | #8 |
Drives: 2010 camaro ss Join Date: Sep 2018
if i were to upgrade to a zl1 pump, would this still be needed? or if i got a voltage booster, would i be ok with just the stock ss pump? mod list in signature
2010 Cyber Gray Metallic 2SS/RS LS3 6 Speed -- Rotofab CAI | Stainless Works Longtubes w/ high flow cats | Muffler Delete | TSP 229/244 stage 2 cam| TSP .660" Spring Kit | TSP CNC Ported Heads | Mulling high volume oil pump | PTB | Trunnion upgrade | Hurst short throw shifter | Elite Engineering Catch Can | Exedy stage 1 clutch |
11-19-2018, 09:14 AM | #9 | |
Please list your car details and mod list so I can better help you with what else you need. Thank you Ted.
11-19-2018, 09:31 AM | #10 |
my car is 2010 Cyber Gray Metallic 2SS/RS LS3 6 Speed. mods are Rotofab CAI | Stainless Works Longtubes w/ high flow cats | Muffler Delete | TSP 229/244 stage 2 cam| TSP .660" Spring Kit | TSP CNC Ported Heads | Mulling high volume oil pump | PTB | Trunnion upgrade | Hurst short throw shifter | Elite Engineering Catch Can | Exedy stage 1 clutch | Zl1 Fuel injectors
11-19-2018, 09:34 AM | #11 | |
11-19-2018, 12:17 PM | #12 | |
11-19-2018, 12:26 PM | #13 |
what does the control module do?
11-19-2018, 12:39 PM | #14 |
