Old 12-06-2016, 12:10 PM   #1
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
Radar detector-hard wired in question.
I want to hard wire (direct wired) in my detector cable. I called the company but after 15 min on hold figured it would be faster here. I see on their web site a couple different cables. Does anyone know which would be the correct one as well as how do i hook it up? Thanks
https://www.beltronics.com/store/straight-cords/
cornerspeed92 is offline   Reply With Quote
Old 12-06-2016, 01:59 PM   #2
CreeperRS
CreeperRS's Avatar
Drives: 20’ Chevrolet Camaro 2SS 1LE
You can do it two different ways, you could tap in the overhead console passenger air bag light. http://www.camaro5.com/forums/showthread.php?t=461297
Or, you could use the driver side fuse panel, by using post #3 to view the fuse that you can tap in. http://www.camaro5.com/forums/showthread.php?t=455241
CreeperRS is offline   Reply With Quote
Old 12-06-2016, 02:12 PM   #3
Rainbow1616
Rainbow1616's Avatar
Drives: 2011 Inferno Orange Camaro 2SS/RS
Pick the "Direct Wire" cord that matches your model number.
Rainbow1616 is offline   Reply With Quote
Old 12-06-2016, 02:14 PM   #4
cornerspeed92
Thanks creeper
Old 12-06-2016, 02:22 PM   #5
cornerspeed92
Thanks, they all did
Old 12-06-2016, 02:22 PM   #6
CreeperRS
CreeperRS's Avatar
Originally Posted by cornerspeed92 View Post
Thanks creeper
No problem, bro.
Old 12-06-2016, 02:24 PM   #7
Rainbow1616
In that case pick the cheapest one of those.
Old 12-06-2016, 03:12 PM   #8
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
For mine I wired into the driver side fuse panel. Tucked the wire along front of headliner, down a pillar, then across bottom a pillar/dash into the fuse panel. I attached a fused tap like shown and plugged into one of the accessory fuse locations so it is switched to IGN. Gnd just goes under a bolt in the panel. Didn't want to mess with airbag lights or anything in the mirror.
Old 12-06-2016, 07:42 PM   #9
CreeperRS
CreeperRS's Avatar
It's just a light, nothing that could set off the air bag, so don't worry.
Old 12-06-2016, 09:21 PM   #10
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Not home or I'd check, but do our mirrors have power? I directly connected my Passport into the rear view mirror of my Z06. Haven't checked to see if the Camaro has the same capability. Since the Passport was mounted to the mirror, it was a very clean install.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 12-06-2016, 09:29 PM   #11
Homeless Man
Homeless Life Chose Me
Homeless Man's Avatar
Drives: LS3 (sold 4/21)
This is a good video by Vehicle Virgins:
Pity a man in familiar places, who yet feels like a stranger.
Homeless Man is offline   Reply With Quote
Old 12-06-2016, 10:42 PM   #12
djcolopi
djcolopi's Avatar
Drives: @orange_maro
I hard wired my radar detector behind the rear view mirror. I also mounted it to the rear view mirror with the Mirror Mount Radar Detector Bracket - Escort 9500ix, 8500x50, Solo S3, Redline. I purchased it through Amazon from radar mount.
Instagram @orange_maro_
djcolopi is offline   Reply With Quote
Old 12-06-2016, 10:52 PM   #13
hammdo
'It's an experiment'
hammdo's Avatar
Installed mine also with a blend mount:
http://www.camaro5.com/forums/showpo...&postcount=425
-Don
747 RWHP 794 RWTQ
Old 12-07-2016, 07:05 AM   #14
ZED SLED
ZED SLED's Avatar
Based on the years I spent in Passenger Safety at a tier 1 supplier, I'd be more concerned about the potential change in impedance causing the airbag to not go off. Aside from that are you connecting to IGN or BAT? Don't want to have to turn the detector on-off every time I get in and out of the car.
