04-09-2021, 06:24 AM | #1 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
MT ET Drag Slick 28x10.5x15 stiff wall (MTT-3055S)
I've been struggling to hook up on the street so i'm trying a new tire. Just got a pair of these, but I didnt buy tubes. This car is a weekened toy that rarely gets driven, so the tires might sit for a month between drives sometimes.
Do you think I will have deflation issues? I've only been to the track once, so it primarily for good weather street use. Currently on a 325/50/15 ET R radial, but cant get traction on the street. 1st, 2nd, or 3rd.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
04-09-2021, 08:07 AM | #2 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
1000rwhp u arent going to get traction with those either ...
Im sure it will deflate eventually, will depend on how well it seals againt the wheel, just check it before going out or every few days if the car is sitting. Dont want the car to sit on deflated tires. |
04-09-2021, 10:06 AM | #3 |
I backed off one pulley size to lower the power, and I dont expect a dead hook. I was hoping with the DA front coilovers and slicks I could at least stay in the throttle and go straight while it spins some. Right now it just breaks loose, points the car sideways and i have to let off.
But my concern here is the tube. I guess it's better just to buy some tubes...
04-13-2021, 03:37 PM | #4 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
They might need to be topped up once in a while.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
04-29-2021, 06:22 AM | #5 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I'm moving to slicks for the track. Based on the information out there, including talking to M&H, slicks will lose air over time and bias plies flatspot when they sit. If you don't want to have to add air periodically, put tubes in, but that does add unsprung weight. I always check pressure before I go to the track so not a big deal to me. The flatspotting goes away after you drive it for a few miles.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
04-29-2021, 09:25 PM | #6 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
I have found putting some of that green anti flat goo on a sponge and rubbing a coat into the inside of the tire (not leaving a bunch of it in the tire to slop around) helped with loosing less air as it sits.
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
05-04-2021, 10:27 AM | #7 |
My traction issue was greatly improved by the addition of front Strange coilovers. The double adjustability really helps the front end lift. I did buy the slicks, but I'm gonna leave the 325/50/15 radials on until I hit the track.
My buddy just destroyed an axle leaving at 3500 (830whp) so I'm a little hesitant...
