#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics
BeckyD @ James Martin Chevy
Old 03-15-2018, 02:11 PM   #1
chuckclanton
Drives: 2021 Camaro 2LT
"Fuse Pull" valid on GEN6 Camaro?
So....I did the fuse pull on my 2014 after I bought it as the car seemed to lack
power. Made a big difference. Previous owner must have used cheap gas!
So I just got a 2016 LT V6 and want to do the same. Works on the Gen6?
Same fuses?
chuckclanton is offline   Reply With Quote
Old 03-15-2018, 02:26 PM   #2
Gen6 softtop
Drives: Hyper blue 1ss convertible 6 sp
On SS I seen no difference loud or performance put it back in. Not sure if the v6 has the sound tube hooked up to air box? If so there is a 2-3 in piece of foam in there which reduces intake sound! Removing gives nice intake sound during hard acceleration
Gen6 softtop is offline   Reply With Quote
Old 03-15-2018, 02:36 PM   #3
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Makes no diff on gen 6
Glen e is offline   Reply With Quote
Old 03-16-2018, 12:39 PM   #4
Ecchi667
Ecchi667's Avatar
Drives: 2016 Camaro 2SS, 6spd M
Same fuses?
What are you trying to achieve? If it's the NPP valves you're talking about, then yes you can do the fuse pull and it will keep them open at all times.
If you're trying to "reset" the car, then just pull the negative cable off the battery and leave it for 30 minutes or so and then reconnect to the terminal. It'll then relearn as you drive. The battery is behind the rear passenger-side quarter panel, accessed from inside the trunk.
Ecchi667 is offline   Reply With Quote
Old 03-17-2018, 01:44 PM   #5
SS Life
Drives: 2017 Hyper Blue 2SS
There's a noticeable difference on the SS. It will be more louder and will sound like it's in track mode when it's in tour.
SS Life is offline   Reply With Quote
Old 03-17-2018, 02:25 PM   #6
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
You guys are going way off topic. He's not talking about a fuse pull for exhaust, he's talking about resetting the fuel octane Maps in the ECU which you could do in a gen5 if 87 was used. You do not need to do that with an a gen6 ECU. (and the gen 6 v6 uses 87 anyway)
