Old 10-14-2019, 03:35 PM   #1
Jdr1337
Drives: 2010 Camaro 2SS Manual
BCM parasitic draw
I have a 2010 SS, and have a parasitic draw issue. I have tested and isolated it to the circuit fed by fuse f14 in the trunk, which is the BCM if I read the diagram on Chilton right. If I don't pull that 5 amp fuse the battery will die over a 2 day period of sitting. Has anyone else experienced this? Is this indicative of a bad BCM? I also hear about 5 loud tapping noises in rapid succession within a few minutes of starting the car, emanating from the trunk area. Is there a relay there that sticks or something?
Jdr1337 is offline   Reply With Quote
Old 10-14-2019, 03:50 PM   #2
G8One2
Drives: 2014 Camaro 2SS
What circuit is F14
G8One2 is offline   Reply With Quote
Old 10-14-2019, 03:54 PM   #3
Camaro__ss
Drives: 2013 L99
All the fuses in the trunk are hot all the time, any aftermarket stuff tapped into the fuse box like an aftermarket amp or lights? Or maybe the mylink amp isn’t shutting off? Clicking might be fuel pump? These things can be impossible. I had a parasitic draw on my vette I only “fixed it” by trading it in.
Camaro__ss is offline   Reply With Quote
Old 10-14-2019, 04:07 PM   #4
G8One2
Fuse 14 on the BCM is for Onstar, i dont think there is a fuse 14 in the trunk fuse block
Old 10-14-2019, 09:45 PM   #5
Jdr1337
It's the only 5 amp fuse in the trunk I see, unless I am not understanding something?
Old 10-14-2019, 10:16 PM   #6
Jdr1337
No nothing like that.
Old 10-14-2019, 10:21 PM   #7
Jdr1337
F14 on the instrument panel block is on star, trunk also has an f14 according to chilton.
Old 10-15-2019, 05:55 AM   #8
G8One2
Well, look at the rear view camera wiring schematic, see where it goes. I believe that's what RVC is. I use Alldata, but I wasn't looking at convertible which it looks like that is. Alldata didn't show any f14 in the rear for non convertible.
Old 10-15-2019, 09:06 AM   #9
Jdr1337
I believe it is actually regulated voltage control.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
