JUICEDMOTORSPORTS
Old 10-18-2019, 10:54 AM   #1
Vegas Bound
Drives: 2013 Sparkly Red One
Idle RPM up and choppy
I don't drive my car often, 14K miles in 7 years. But when I do, it's hard miles at the drag strip.
Wednesday, after a couple passes, my idle RPM jumped up to 1200 while in gear and felt a little choppy.
I put the car on my trailer and took it home.
Any idea what it could be? No CELs.
And no, I don't have a data log.
Lots of bolt on stuff
Bests in each category
1.36 - 60'
6.29 - 1/8 mile
10.18 - 1/4 mile
Vegas Bound is offline   Reply With Quote
Old 10-18-2019, 05:10 PM   #2
Tajefe Couple
Tajefe Couple's Avatar
Drives: Never just fly under the radar
No advice sorry, just hope you get it worked out
Old Skool
Tajefe Couple is offline   Reply With Quote
Old 10-18-2019, 05:25 PM   #3
G8One2
Drives: 2014 Camaro 2SS
Snapped the throttle shut at high RPM, timing jumped a tooth? Just a guess though
G8One2 is offline   Reply With Quote
Old 10-18-2019, 06:52 PM   #4
Vegas Bound
Possible but I hope not. Don't want to tear the front of the engine apart.
1.36 - 60'
6.29 - 1/8 mile
10.18 - 1/4 mile
Old 10-18-2019, 06:53 PM   #5
Vegas Bound
Thanks.
1.36 - 60'
6.29 - 1/8 mile
10.18 - 1/4 mile
Old 10-18-2019, 08:36 PM   #6
Avenging Orange
You give us little to work with....dont expect much in return.
2010 Inferno Orange 2SS/RS M6 Black Leather,Sun Roof, OBX Headers, Haltech CAI , non synthetic fluids, Mike Norris tuned 419/413, BMR Cradle/Diff/front Radius rod/lower control arm bushings/1" lowering springs, DSE 32mm fe4 rear sway bar. GM fe4 shocks/struts/LCA's, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20.
Avenging Orange: 42 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
Old 10-18-2019, 09:21 PM   #7
Vegas Bound
Sorry, it's all I got so far.
1.36 - 60'
6.29 - 1/8 mile
10.18 - 1/4 mile
Old 10-20-2019, 07:42 PM   #8
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Vacuum leak?
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 10-20-2019, 08:53 PM   #9
Vegas Bound
Originally Posted by hunter1660 View Post
Vacuum leak?
That was my first thought. Vacuum leak will rob boost, my power was down. Logical thought. Unfortunately, I can't seem to find where the leak might be. Going to take it in to a local shop for a smoke test and check out the computer.
1.36 - 60'
6.29 - 1/8 mile
10.18 - 1/4 mile
Old 10-21-2019, 07:16 AM   #10
G8One2
Vacuum leak would show itself in your fuel trims.
Old 10-21-2019, 08:31 AM   #11
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2010 Camaro 2SS A6
You haven't told us which engine or anything about your mods.
Rock-It Man is offline   Reply With Quote
Old 10-21-2019, 11:18 AM   #12
Vegas Bound
Boosted V8.
1.36 - 60'
6.29 - 1/8 mile
10.18 - 1/4 mile
Old 10-22-2019, 09:15 PM   #13
JJPlace1
JJPlace1's Avatar
Drives: 2010 2LT Victory Red
Did you check and see if there was oil in the plug hole ? That will and can cause a misfire. It comes from a leaking o-ring in the valve cover . When I changed all my plugs some had a small amount but I have heard of some leaking badly enough to cause a misfire . Just a thought , pull the coil off and look down in the hole to see .
Previous Vehicles
1970 Impala 2D 350/300
1972 Buick GS 350
1967 Pontiac Firebird 326
1969 Chevelle SS 396/375 I really miss this one
1966 Chevelle SS 396/350
1978 Plymouth Fury 440
1982 VW Scirocco ( Got married )
1987 VW Scirocco
1992 Ford Taurus V6
1996 Dodge Intrepid
2002 Dodge Intrepid
2002 Mercedes ML500
2010 Camaro 2LT
JJPlace1 is offline   Reply With Quote
Old 10-22-2019, 09:16 PM   #14
JJPlace1
JJPlace1's Avatar
Never mind , you have a V8 not a V6 .
Previous Vehicles
1972 Buick GS 350
1987 VW Scirocco
1992 Ford Taurus V6
1996 Dodge Intrepid
2002 Dodge Intrepid
2002 Mercedes ML500
2010 Camaro 2LT
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
