Old 10-29-2019, 08:59 PM   #1
mreyna16
Drives: 2014 Camaro SS 2SS
Heated seats not working... Not your average heated seat peoblem
So my heated seats stopped working but it's not your average topic... Most or all topics I've seen show that the lights turn on for a minute then turn off but mine don't even turn on at all... I don't have warranty anymore so it's not like if I can take it to the dealership... Anybody had this and fixed it?
mreyna16 is offline   Reply With Quote
Old 10-29-2019, 09:44 PM   #2
608RS
608RS's Avatar
Drives: 2015 2ss
you might have to dig some more but i believe others have had the same issue and it turns out the wiring inside the seat had to be fixed/replaced. do you know any local upholstery shops nearby that could possibly remove the seat covers and look?
2015 Camaro 2ss, NicKey Performance built/tuned
608RS is offline   Reply With Quote
Old 10-29-2019, 10:55 PM   #3
mreyna16
I've seen that solution but I think it's the solution when the lights on the heated seats button lights up... Mine doesn't do that, wonder if it's the same fix but I'd like to see if anyone has had the same problem before I take off my seats... Yea there's an upholstery shop
Old 10-30-2019, 08:22 AM   #4
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
silly q but did you check all the fuses(s)? also make sure the plug under the seat did not get dislodged due to murphy.
Good luck!
PEACE
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 143K! - All work by me...
Old 10-30-2019, 03:22 PM   #5
mreyna16
Good luck!
PEACE
Yea I thought about the fuses thing too but wouldn't know which one it is... I'll check it out after work...
Also, come to think bout it a while back I had a full auto detail... Maybe these guys didn't connect it right even though my seats are working
Old 11-05-2019, 02:47 PM   #6
myold88
myold88's Avatar
My driver's heater stopped working also. It was posted here with photos how a
wire under the seat gets pinched causing the failure. An easy fix as I remember
after the seat is removed. I have moved to Florida so not a concern for me now.
Old 11-06-2019, 06:11 AM   #7
VCSS11
VCSS11's Avatar
Drives: Chevy Camaro SS
Im having the same issue. I checked the fuse and it was fine (#35 under the hood) I havent checked the connections underneath but what are the chances of that happening to both seats?!
Is there any other fuses for the heated seats? I read the manual and only found that 1
VCSS11 is offline   Reply With Quote
Old 11-06-2019, 06:49 AM   #8
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Compare the ohm reading on a good seat with a bad seat, If they're different suspect the heating element.
FasNuf is offline   Reply With Quote
Old 11-21-2019, 05:10 PM   #9
mreyna16
I checked the fuzes and connector too... They seem fine. And just like u, I thought to myself what are the chances of both sets of wires get burned out... I have yet to remove my seats, time hasn't allowed me to try and diagnose the wiring on 5he back of the seats... Might just try and unzip them from the back without removing them see if I see burnt wires... Let me know if u find a solution
Old 11-21-2019, 10:43 PM   #10
Camaro__ss
Drives: 2013 L99
It was pretty easy to remove seats. I took them out to clean carpet. As I recall: d/c battery, one bolt on each seat slider on the rear side, pickup and slide back an inch or two, unplug the wires and they come right out. I don’t know anything about the heaters though
Camaro__ss is offline   Reply With Quote
Old 12-01-2019, 07:22 PM   #11
mreyna16
UPDATE: So I went ahead and removed my seats, checked wiring and everything looked good... Put my seats back and now the heated seats are working... I'm thinking the connection was somehow not connected right? Don't really know but my wires weren't burned... Thought I'd update u guys
Old 12-02-2019, 08:01 AM   #12
608RS
608RS's Avatar
Drives: 2015 2ss
glad it was an easy fix lol, probably a bad connection or something. hopefully doesn't return again!
Old 05-12-2020, 06:40 PM   #13
legbuh
Drives: 13camaroZL1v,06 911, 13vwR, nissans
Are they still working? I have the same issue where both won't turn on at all. Just bought it as a used 13 ZL1. I never thought of testing them before I bought it..
No huge issue. If disconnecting them and reconnecting worked, maybe the connectors are getting corroded for some reason.
legbuh is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
