#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
Old 03-07-2021, 11:02 AM   #1
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Which headers to get or even get them.
Ok, doing the cam install soon. Which headers should I get or even get them. I installed Kooks headers 1 7/8 LT last time on my 2016.
This time I am not sure what route to go but ready to order and pay.
1.) I was thinking of the Jet Hot kooks 1 7/8 or 2 inch? $1300 ish
2.) Texas Speed Performance Headers 700 ish
3.) Speed Engineering Headers. $370 ish
The range in price is from around $1300 to a low of $370. Of course there must be some consideration of quality of build. But is it like buying a Nike runner compared to a lesser shoe that still does the job. Plus the ceramic coating is it worth the extra money to go with them vrs the TSP Headers? I do want a cooler engine bay but the Nitrous does that internally. Hmmm I am not 100 % sure yet which route to go.
LT4 1.7 Supercharger snout ported & Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 03-07-2021, 12:11 PM   #2
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Depending on the specs of your cam, most cams will benefit from the better breathing provided by LTs. Typically a cam will move your power band to higher rpm levels and that is where you want better, more efficient exhaust flow/and less back pressure. Kooks and ARH are typically at the top in terms of quality of the metal, welds and fit. I would highly recommend having them coated. Also, invest in some plug wire sleeves for additional protection from heat breakdown and burnt wires.
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 03-07-2021, 01:01 PM   #3
BlackbeastSS2
The cam is the EL C7 TSP. Have header socks from other build. I have purchased already Smith Brothers LS / LT (Gen 5) Bronze Trunnion Upgrade Kit, TSP 660 springs, LS7 lifters but I might go to the GPI LS7 race lifters. If I had known about those before getting the LS7 lifters I would have. BTR harden rods. I am thinking of seriously upgrading the valves to a harden stem.
After headers the next purchase is the GPI drop in pistons at the end of this month. So I am just about finished collecting all parts, gaskets, oils, fluids, etc.
I guess I will give Texas Speed a call tomorrow to see which headers they recommend 1 7/8 or 2 inch with my build.
Old 03-07-2021, 04:36 PM   #4
enzia35
Drives: '16 Garnet Red 1SS
Don't get the Jet Hot Kooks. They're made from crappier quality steel than the uncoated ones.
'16 Camaro 1SS
'18 Miata GT
Gone: '01 Camaro, '14 Camaro, '90 Miata
enzia35 is offline   Reply With Quote
Old 03-07-2021, 11:21 PM   #5
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
The jet hot ones are 409 stainless instead of 304. If you get them coated it really won’t make a difference. I bought my catted TSP headers NIB from another member for 700$ had them coated locally for 250$ . My vote is for the TSP headers.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
Old 03-07-2021, 11:30 PM   #6
Trochoidal
Drives: 2017 Camaro 2SS A8
Makes you wonder if all coated headers that are being sold are 409, hence the “free” coating.
https://help.summitracing.com/app/an...nless-steel%3F
Roto-Fab w/sound tube delete, Katech ported TB, Pray IM, Velossa, DD side markers, DSX FF, UPR Catch can, Halo brace, My custom vent gauge pod
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“
Trochoidal is offline   Reply With Quote
Old 03-08-2021, 04:20 AM   #7
BlackbeastSS2
Thanks for info, leaning to TSP now.
Old 03-08-2021, 05:09 AM   #8
s346k
s346k's Avatar
Drives: like an old lady
camshaft? yes, install headers.
about a year ago i went with 2" speed engineering headers. no complaints. fwiw i've NEVER seen a ceramic coated header hold its coating. ever. this goes for tsp, flowmaster, pacesetter, kooks, thorley, banks...not one of them. be it factory coating or jet hot, doesn't matter.
2016+ camaro: everyone’s first car
s346k is offline   Reply With Quote
Old 03-08-2021, 05:50 AM   #9
Robby23
Drives: 2018 1SS M6
go 2" headers. some will say you don't need them until like 700+but there is no negative side to running 2" over the 1-7/8 plus if you do more mods you already got the bigger headers. I know of someone who actually customized bigger then 2" headers and seen 22 rwhp difference on a 416 NA motor. TSP is best bang for your buck. i got my headers non-catted new for 650 and had them locally ceramic coated for like 150 bucks. fitment was good and no issues in 2 years use.
2018 1SS M6 - OTR intake, HI Ram intake, Ceramic Coated TSP Headers Catless, AWE Touring Axle-Back, Flex Fuel, Pray Performace stage 3 cam, TSP ported heads, Pray Ported 95MM TB and Ported HI-RAM. SJM Line-Lock. F14 Drag Pack 17's with front skinnies. Tuned by Pray Performance.
Robby23 is offline   Reply With Quote
Old 03-08-2021, 06:16 AM   #10
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
Coatings are trash.... especially jet hot. My jet hot hooker headers lost their voting after a year
2" headers, 10 times out if 10. 1 7/8 longtube headers belong no where near a 6th gen
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 03-08-2021, 09:47 AM   #11
overdriv
overdriv's Avatar
Drives: 1969 Chevelle SS 2019 2SS Camaro
I have had two sets of Hedman Elite headers ceramic coated on two different BBC engines.
The oldest set is now seven years old and the coating on both looks as new.
I will never have a set of headers without ceramic coating.
My 2 cents.
overdriv is offline   Reply With Quote
Old 03-08-2021, 10:56 AM   #12
GrayLT1
Drives: Chevrolet Camaro
I would probably go with AirBorne coatings. From what I understand this is the guy who started Jet Hot and sold the business to some other company. He started this business after selling Jet Hot.
Of course please confirm all of that if/when you talk with them.
GrayLT1 is offline   Reply With Quote
Old 03-08-2021, 11:19 AM   #13
BlackbeastSS2
Anyone no if that heat ceramic paint actually helps with the heat when you spray your headers with a rattle can.
Old 03-08-2021, 01:05 PM   #14
seethruya
Drives: 2021 Camaro LT1 Conv
If you’re not installing the headers yourself, why the Texas Speed Performance Headers over the budget Speed Engineering Headers?
seethruya is offline   Reply With Quote
