03-23-2020, 12:39 PM | #1 |
Drives: 2015 ZL1 Join Date: Feb 2020
E85 questions!
So I currently have headers, Corsa and RF intake with Elite catch can! Going for tune next Monday! When I got on here for my first round of mods. I got some real good advice. So now I’m looking at round 2 of mods. I wanted some more advice.
I’ll be doing the next round of mods within the next 6 months and going for a retune! I was curious. I currently have 850cc injectors + BAP, on my list bc I hadn’t fully committed to e85. I have now. From my understanding I’ll need 1200cc + injectors? And a dual 450 fuel pump? Or will a BAP be sufficient? I’ll also be using a GPI flex fuel kit. Will this setup work or will I need anything else? Injectors, flex fuel kit and BAP / or dual fuel pump? I’ll also be running a 10” crank pulley, idler relocation bracket + 70” green gates belt, AFCO dual fan HX, 160* thermostat, NGK TR7IX plugs, reinforced intercooler brick and that should be it. Anything I’m missing? Also generally speaking with all those mods. What are dyno # like with those mods? I don’t even know what the car will make with just headers, cat back and intake + tune. Let alone all that plus e85, cooling mods and pulley swap. |
03-23-2020, 12:54 PM | #2 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
I went with 1300s and a DSX aux pump for e85. 2.5/9.5 pulleys.
03-23-2020, 01:07 PM | #3 |
03-23-2020, 01:49 PM | #4 |
03-23-2020, 01:57 PM | #5 |
Drives: 2014 ZL1 Join Date: Apr 2018
Search function could be very helpful here.
03-23-2020, 03:35 PM | #6 | ||
I did search. I just found so many different variables, setups and answers. I wanted a more direct, up to date reply. Quote:
Will I need anything else? 1200-1300cc injectors, DSX aux kit, and flex fuel kit? |
03-23-2020, 03:55 PM | #7 | |
Cold air, headers, cam, springs, flex fuel kit, aux pump, injectors, pulleys and a good tune should net you 750ish. I put meth injection on top just for security. I'm at 757 through a 4L80 on a conservative tune in 3000 DA. Then you will need suspension upgrades and decent set of wheels and tires to put the power to the ground. |
03-23-2020, 08:21 PM | #8 | |
I didn’t really wanna do cam. I do however plan on doing some suspension mods. Toe and trailing arm BMR upgrades and 17x10 wheel w/ 28x10 Hoosier at some point. For now I have headers, intake, Corsa and tune next week. I plan on doing 1200-1300cc injectors, E85, flex fuel kit, aux pump, 10” crank pulley with all supporting mods. And cooling mods (dual fan HX, 160* thermostat, SC coolant res, etc) to prevent as much heat soak and HP loss as possible. Hoping for 750 or close to it. |
03-23-2020, 10:07 PM | #9 | |
Better add reinforcing the brick to the list with that lower pulley. |
03-24-2020, 08:02 AM | #10 |
03-24-2020, 08:51 AM | #11 |
750 without a cam is going to be difficult.
03-24-2020, 08:59 AM | #12 |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
If you're doing 1300's and aux pump, I would also consider new rails. And while you're in the bay a Melling oil pump. And if you're doing all this I don't understand the reticence of a stage 2 or 3 cam...it will get you where you want to go in a hurry.
03-24-2020, 09:56 AM | #13 |
03-24-2020, 01:03 PM | #14 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Slide a BTR 1 or 2 in there, or a GP Tuning 1 or 2. If you want it to sound totally stock, put in an LS9 cam. Even the LS9 cam is worth 25-30rwhp over the anemic LSA cam. And of course the BTR and GP Tuning (or other "small" / "stage 1") cams will make even more than that.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
