03-21-2015, 09:48 PM | #1 |
Drives: 2012 Camaro ZL1 Join Date: Jun 2014
Manual transmission removal the easy way
So I just got done installing a new clutch in my car and I have found a much easier way to remove and install the transmission. I took it out the hard way and after fighting with it for 3 hours couldn't get it installed, figure out this way during the install. On top of that I added a remote bleeder from Tick and did not realize the hose was screwed on to the fitting, so it leaked had to pull the transmission again to tighten it up. I was able to pull it and install it in a day with a lot of breaks, taking pictures and keeping a list of what I did step by step. I am not doing a in depth write up for the entire clutch install because I already had it installed. This is accomplished by lowering the the engine cradle and allows for a lot more room for accessing bolts, your don't have to rotate to get the trans out or back in because of clearance issues.
#1 Remove exhaust - easy, loosen blots on clamps and un hook from hangers. Remove catalytic converters if your dont have headers. With headers all I had to do was remove the o2 sensors. I have removed the trans with both the stock system and long tubes. I was able to do this by myself, but 2 people is easier. #2 Remove driveshaft - you will need a 18mm socket and 19 mm wrench to remove 3 bolts on tailshaft. Use 18 mm socket to remove 3 bolts where it connects to rear diff. Remove driveshaft support with 13mm socket 2 bolts #3 support transmission with a transmission jack and remove transmission support held in place by 2 nuts and 4 bolts. #4 Remove trim around shift assembly inside car. It just pops up. I used a flathead schrewdriver. #5 Twist and slide down metal collar on shifter to push boot down and access the set screw. Remove set screw and twist and pull up on shift knob. #6 Remove 4 bolts that secure shift assembly to tunnel. I believe they are 10mm. #7 Lower transmission as far as it goes and began removing all the electrical connectors #8 Disconnect coolant lines . I used a utility knife to remove retaining clips and then pull them apart. I placed a glove and rubber band on each end of the lines to keep fluid loss at a minimum. #9 Disconnect hydraulic line to slave cylinder. Same method as the coolant lines and gloved this as well. Sorry no pic, stole the pic from member h018871. #10 This is the issue as the why you dont get the same clearance as the SS. The blower hat hits the firewall not allowing it drop any further resulting in terrible clearances. I really began questioning how I was going to get it back in and the bolts started. So this is where we start working on getting our extra clearances. #11 Disconnect the rod that connects from the control arm to the mag ride sensor. I thought that it was all one unit and came down with the cradle and they broke. Below is the result. Taped them up out of the way until I can get it replaced. #12 Unbolt the shock mounts. 24mm nut i believe #13 Support the engine cradle with a jack. #14 Remove the 2 21mm bolts for the engine cradle closest to the front of the car, get a good idea how long they are and thread them back in maybe half way. #15 remove and dont reinstall the 21 & 24mm bolts at the rear of the engine cradle. 2 per side. #16 Lower the jack supporting the engine cradle enough that where the last bolt (24mm) was is about 3" lower. The cradle will tip down towards the rear. Really wish I got a pic of that. Now you have a million times more room to get the bell housing bolts off and when removing the transmission yo dont have to rotate it anymore. Now you can just separate and lower the transmission. #17 Remove shift linkage assembly? You may not have to do this anymore with the extra clearance. I did it anyways and its not difficult. I found for me it was easier to access from up top reaching my hand through the tunnel. There are 3 pins that need to be removed. The one in the middle just use a flatblade screwdriver to remove 1 retaining clip and push pin out. The 2 on the outside use a flat blade again but if you look close at them they have a tab on one side, get your flat blade under there and pull up and rotate them. Once they are rotated out of the way they can be pushed out. Its actually real easy. #18 Remove bellhousing bolts 15mm. I didn't need the 4' extension anymore but you could still use it. #19 Separate transmission from engine. I actually used a 1" wood chisel and started at the bottom where a gap already exist and carefully separated the transmission working it on both sides until I got as far up as I could on both sides. Gave it a bit of a wiggle and it pretty much fell out. I didn't keep up with installing the clutch since these notes and pictures came from having to remove the transmission again to tighten the remote bleeder line. - Remove pressure plate - Inspect flywheel, if hot spots are present or any irregularities remove it. Either replace it or get it resurfaced. I got mine resurfaced and the machine shop said he has done many dual mass flywheels and thinks its just a ploy to get you to buy a new flywheel. I'm still breaking in my clutch so I haven't driven it hard, but it is smooth as butter compared to before and no problems. - replace pilot bearing - Reinstall flywheel - Reinstall pressure plate and bolts finger tight - Align clutch with pilot bearing. Visibly check to make sure it is aligned. - Tighten all pressure plate bolts to 11 lb/ft - Tighten all pressure plate bolts to 26 ib/ft - Tighten bolts 1, 2, & 3 in sequence to 41lb/ft - Tighten bolts 4, 5, & 6 in sequence to 52 lb/ft - Reinstall transmission and the rest of the steps in reverse order.
11.633 @ 118.85 Stock M6 Drag Radials
03-21-2015, 10:39 PM | #2 |
Snake Eater
Drives: 2012 AGM ZL1 Join Date: Oct 2011
Nice, I'll remember this when I do the auto to manual swap in the future
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ Follow me on instagram: http://www.instagram.com/snkeatr/ |
03-22-2015, 08:43 AM | #3 |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
Good tip regarding lowering the cradle. I've not bought the Helm's manuals for this car yet. Anyone know if that is the factory procedure too? Makes sense as I've had to really tip back other LS engines to get the Tremec back in.
Here's another tip. Buy one of these
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
03-22-2015, 11:55 AM | #4 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
03-22-2015, 12:33 PM | #5 |
It wasn't much. 12-16" Just had it on jack stands. I'm 6'4" it was cramped. Here is a picture of me wedge in there making sure the clutch was lined up properly. The tool I used was universal that slid into the pilot bearing with a tapered slide piece that didn't center it. I had to do it by eye.
03-22-2015, 12:42 PM | #6 |
I measured my jack stands. They are 16"
03-22-2015, 02:23 PM | #7 |
06-20-2015, 08:58 PM | #8 |
Drives: Camaro Join Date: Dec 2013
I just used these instructions to change my clutch and it made changing the clutch 1000x easier. I've never had a transmission drop performed so easily and these instructions really really helped.
06-20-2015, 09:03 PM | #9 |
Glad it helped. Lowering the engine on the cradle really helps and just makes this job pretty easy.
06-21-2015, 07:00 AM | #10 |
Drives: 2013 HWSE Indy Festial #26 Join Date: Mar 2011
The best part of this forum is posts like these. I have spent time on my back under my ZL1, putting headers in, and this gives me confidence that a clutch replacement wont be too bad. Thanks for taking the time to post.
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan |
06-21-2015, 08:05 AM | #11 |
Drives: '21 ZLE A10 Join Date: May 2012
nice writeup! That looks like my kind of job...
06-23-2015, 05:26 PM | #12 |
Sorry just curious but why are you replacing the clutch?
I ask this cause my wife's just got towed to a dealer this morning cause the slave cylinder took a dump. The service writer said while I was there taking him a monster clutch bearing retainer, that he's never had to replace a Gen 5 clutch yet. Even though they see dead slaves a lot, no clutches have needed to be replaced.
Fix your garage pics so we can see them |
06-23-2015, 05:54 PM | #13 | |
Too much racing at the drag strip and my attempt of getting one of the best if not the best times stock with drag radials only for a manual car. It took a lot of trial and error and practice. Was able to get several runs at 11.6 on different days in good air until it died. Even ran 11.8 on the death run with a lot of slip. I got 23k out of the clutch so I think I did OK on miles before it died. I just did a 125whp pkg from Jannetty and I'm having to learn again. Hopefully more great times in the future.
01-13-2016, 08:42 PM | #14 | |
Pilot Bearing removal an install
