03-08-2011, 11:34 PM | #1 |
Drives: 2010 rally yellow 2ss/rs m6 Join Date: Apr 2010
tunnel brace question
just installed flow master american thunder 3" catback. but the tunnel brace wont bolt back on it would be sitting against the exhust. stock one & the one i got from elite. help appericiated. thanks to all in advance
03-09-2011, 02:37 PM | #2 |
Drives: One of the rare ABM camaros Join Date: Apr 2009
I have that exhaust on my LS3 and didn't have any issues. Try twisting the pipes around and see if that gives you any clearance. I suppose you could put some washers between the brace and the car to space it out a abit to create some space.
Good luck (and it does sound awesome) Dean
2000 5/23 3000 5/27 3400 6/20 TPW of 6/29 3800 7/3 4D00 7/8 interned at QC 4B00 7/16 Released from QC 4200 7/20 8/5 We picked up the car |
03-09-2011, 02:41 PM | #3 | |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
I had the same thing happen to me on my flowmaster. I put washers on my brace...and then I bought an LSR Tunnel brace which gave some more clearance because I couldnt handle having something rigged like that on my car. But then when I was under it I seen that if I would have just twisted the pipes up it would likely clear the stock brace. To the OP...you need to twist the pipes inward and up so to speak. If you think it sounds good now...try some headers and ORX....it is amazing. |
03-09-2011, 03:41 PM | #4 |
Drives: 2010 2SS/RS IBM / Silver Stripes Join Date: Mar 2010
I had the luxury of installing my Flowmaster AT on a hoist. This allowed me to "push up" on the pipes while my buddy tightened everything down. Didn't need any washers for the cross brace. If you don't have a buddy to help you use a jack. Loosen the bolts then lift up the pipes with the jack then tighten back up real tight.
Also, make sure the pipe is not upside down where the "X" pipe is. You should be good to go. M |
03-10-2011, 07:28 PM | #5 |
So flip the x pipe around so the flow master logo is facing up and not facing the ground?
03-11-2011, 08:30 AM | #6 | |
No, I believe "Flowmaster" should be facing the ground. If it is, you may just need to loosen the clamps both front and back, then push up on the pipes with authority and hold them up while a friend re-tightens them. Hope this helps. Mine fits fine with the OEM brace. M |
03-11-2011, 11:29 AM | #7 |
Thanks bro
03-11-2011, 01:13 PM | #8 |
Drives: 1972 Camaro Z28 Join Date: Aug 2009
Hey SyracuseBaller,
The great thing about this message board is everyone is really trying to help their fellow members. The Flowmaster logo on the X-pipe should be facing the ground. It should not be facing the underbody of the car. As the other members stated, if your exhaust is hanging down and not allowing you to install your tunnel brace, you will need to loosen all the clamps and push the exhaust upwards while tightening the clamps. If necessary, get somebody to help you. Don’t leave the brace off. It’s an important part of the Camaro underbody structure. If you have further questions, please call our tech line. It’s toll free. 1-800-544-4761 |
03-23-2011, 12:18 PM | #9 | |
Hell yeah I'm Guilty.....
Much of the equipment and tech advice is being donated..the rest we find here on Camaro5...and yes it is awsome that we all help each other!!!! Best board I have been on ever.
03-23-2011, 01:47 PM | #10 |
Drives: 2010 Camaro 2SS RS, Black Join Date: Sep 2009
Someone in another thread suggested pushing a wood wedge in between the brace and pipe before your tighten everything up, then slipping the wood out.
03-23-2011, 02:10 PM | #11 |
Drives: '17 Fifty SS - '18 Traverse Redline Join Date: Jul 2009
That works too...I used a jack and jacked it up as high as it will go and then I tighten the bolts and I had space between the brace and exhaust pipes. I did order a tunnel brace from Elite Engineering and it added more clearance.
2017 Camaro SS -"FIFTY"
Mods: "93 Octane" |
03-29-2011, 07:19 AM | #12 |
Drives: 2010 2ss/rs M6 Join Date: Nov 2010
I just went through this with the stock exhaust hitting that brace. I bought 4 hard rubber and 4 metal washers and put them between the brace and the frame. Problem solved
Similar Threads | ||||
Elite Engineering Tunnel Brace | AZ5G | Vendor and Seller review / feedback / experiences | 1 | 02-12-2011 11:26 PM |
Stainless Works V-8 Catback exhaust tunnel brace clearance? | Frayles | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 09-27-2010 07:36 PM |
Tunnel Brace question.......... | 2010IBMSS | Suspension / Brakes / Chassis | 8 | 05-18-2010 02:47 PM |
BMR DRIVE SHAFT TUNNEL BRACE | Robert@LateModelSpeed | Exterior Parts & Accessories | 1 | 05-10-2010 01:07 PM |
BMR Launches New Product - 67-69 F-Body Convertible Tunnel Brace | BMR guy | 1st & 2nd Gen Marketplace | 1 | 05-07-2010 02:19 PM |
