Gen5DIY
Old 06-21-2018, 01:36 AM   #1
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
Summer 6L80 Trans temp
Hey guys I need some opinions. I live in AZ and the temps get pretty hot here my car runs a little above 180 during stop and go traffic and can get even hotter with sprinted driving. Is this a ok operating temp? I’ve searched extensively through the forum and most everyone says,” mine never gets over 180.” So any help is appreciated.
L99: Kooks long tube with off-road pipes, CAI brand intake, Borla Atak cat back, 19” forgstar wheels, tuned by Cordes Performance Racing, various visual mod including (2) 5”x5” America flag stickers. 366 Hp 380TQ
Athletics101 is offline   Reply With Quote
Old 06-21-2018, 02:14 AM   #2
Overflow
Space Shuttle Aficionado
Overflow's Avatar
Drives: 2010 CGM 2SS/RS
That's usually where mine hangs. It'll get up to a little over 200 F when I'm doing some spirited driving. This is up in North Dakota during 70 - 80 F weather. Haven't had a chance to check it during out -30 F winters yet.
2010 Chevrolet Camaro CGM 2SS/RS
Old 06-21-2018, 02:20 AM   #3
Athletics101
Drives: 5th Gen L99
So yours is a little over 180? As well ok good to hear that mine isn’t an outlier of sorts.
Shouldn’t it essentially be around the same temp as the coolant?
Old 06-21-2018, 02:47 AM   #4
Overflow
Overflow's Avatar
Yes. It's always somewhere around there. The normal trans temp is anywhere between 160 to 200.
Also, yes. They should be around the same temperature. But it's nothing to freak out about if they're somewhat different.
Old 06-21-2018, 03:04 AM   #5
Athletics101
Drives: 5th Gen L99
Ok! I really appreciate it. I thought it was too high and I was hurting my transmission daily. So I figured i post about it. I did buy an external trans cooler recently but Haven’t had time to install it.
Old 06-22-2018, 01:46 AM   #6
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
mine gets to that exact point at the highest in stop and go and I run a 5000 stall. Your good.
Old 06-22-2018, 02:22 AM   #7
Athletics101
Drives: 5th Gen L99
Thank you! I appreciate the insight. Hopefully down the road this thread answers someone else’s question.
Old 06-22-2018, 07:31 AM   #8
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
I have a heads, cam, etc., A6 with 3200-3400 stall.
The temp is about the same as yours...
2010 Cyber Gray Camaro 2SS RS A6
Circle D Specialties 3200-3400 Conveter
Cold Air Inductions CAI
JRE CAI Scoop + RotoFab Washer Bottle Relocation Kit
Kooks Jet Hot Ceramic Coated Signature Series 1-3/4 to 1-7/8 Stepped Headers
Kooks full true 3in exhaust
Trick Flow GenX 255's with Polished PAC .660's and Ti-retainers
Texas Speed VVT 3.2 cam kit w/DoD Delete
Texas Speed 1.72:1 Roller Rocker Arm Set
AEM X-Series OBDII Widebands
Fuel Injector Clinic ID850 Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Fuel Kit + E85
NGK Iridium IX spark plugs
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 06-22-2018, 12:34 PM   #9
Athletics101
Drives: 5th Gen L99
Thanks for the input. I feel reassured.
Old 06-22-2018, 05:54 PM   #10
jc615
jc615's Avatar
Drives: Camaro and Sierra
In Texas I ran a 40k TruCool trans cooler and it usually stays around 180 mark. I run 4000 stall
jc615 is offline   Reply With Quote
Old 06-22-2018, 06:28 PM   #11
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 Summit White 2LT/RS
Yeah, if you're concerned about it at all, grab a transmission cooler. It'll give you peace of mind.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I
DSX_Camaro is offline   Reply With Quote
Old 06-23-2018, 12:15 AM   #12
SSeniorMoment
Drives: 2010 2SS RS L99 IOM
I'm running cam, heads, 3600 stall and have a large AT cooler that keeps temps <180F most of the time. Slow speed mountain driving, no stop and go where I live, will bring temps up a bit, but "regular" driving keeps temps in check with the cooler.
SSeniorMoment is offline   Reply With Quote
Old 06-23-2018, 10:16 AM   #13
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro SS
X-2 mine maintains 180 even in ambient temperatures as high as 125+ degrees.
Pro-tuned is offline   Reply With Quote
Old 06-25-2018, 11:19 AM   #14
qcman
Drives: 2013 Camaro 2SS RDP Tuned L99
OP mine runs there more often than not. I too heard the "my trans never goes over 180" speak on here. I got paranoid and added a cooler at my dealer even though they said my temps were fine and it still runs the same temps in traffic. It cools faster afterward when moving which is better I think.
But here is what I figured out with my car. I rarely use the AC so my coolant gets up to about 105C or 221F then the car cools down to around 95C once the thermostat opens. And then back up it goes cycling in temperature. So the trans cooler in the radiator is being heated by the coolant....
If I run the AC my coolant never goes over 93C or about 200F and my trans stays at about 180 pegged. Now it could be the fans blowing over my trans cooler but I doubt its that. So maybe try what I'm saying to see if yours behaves similar. I think the cooling system is set up to run better with the AC on overall.
qcman is online now   Reply With Quote
