Emblempros
Old 07-12-2018, 09:26 PM   #1
Jburnham54
Jburnham54's Avatar
Drives: 2010 Camaro SS
clutch issues cant find an answer
i installed a mcleod rxt clutch, new slave/throwout, new master, ticks speed bleeder and remote reservoir. bench bled master and slave. i have vacuum bled, truttled the shit out of it. im not longer getting air. i have some pressure. but when i crack the bleeder it sticks to the floor. the fingers on the clutch are all even. spacing is correct. ive literally got about 20 hrs into this thing trying to bleed it. the clutch engages and disengages good but its only about an inch off the floor. any help would be greatly appreciated.
Jburnham54 is offline   Reply With Quote
Old 07-12-2018, 09:36 PM   #2
Jburnham54
Jburnham54's Avatar
is it not getting enough fluid? still have stock clutch line. seems like twin disk should have more pressure.
Old 07-12-2018, 11:24 PM   #3
samgray20
samgray20's Avatar
Drives: 2010 CGM 2SS/RS M6
I feel like I'm missing something. Are you pulling the pedal back to the top when bleeding it?
Sent from my SM-N950U using Tapatalk
2010 CGM 2SS/RS M6 - Comp 227/243 .620/.612 | Nitrous Outlet Plate Kit - 100 Shot | ARC Bottle Bracket/Heater | NOS Progressive Controller | AEM Wideband | Kooks 2"x3" LTs | 3" Custom Catback | CAI Intake | Bo White PTB | Billet Motor Mounts | Hurst Short Throw | McLeod RXT | RAM TOB | 3.91 W/ Eaton Truetrac, LPW Cover, Poly Bushings, GForce 850HP Axles | Eibach Pro-Plus Kit | Whiteline End Links | Hotchkis Tower Brace | ZL1 Front End | Blue Powder Coated Calipers | Vorsteiner V-FF 101 - 20x11 and 20x10 | M/T Street Comp - 305/35 and 275/40 | 2 JL Amps | Diamond Audio Speakers | JL Stealthbox
samgray20 is offline   Reply With Quote
Old 07-13-2018, 07:16 AM   #4
Jburnham54
Jburnham54's Avatar
yes, have a bungy cord hooked to it to return it.
Old 07-13-2018, 07:25 AM   #5
samgray20
samgray20's Avatar
What are you using to press the pedal? The procedure should be pump the pedal a few times, open the bleeder, press the pedal to the floor, close the bleeder, then pull the pedal back to top and repeat. The pedal won't come back on its own after bleeding because you have just bled all of its fluid out and there is nothing pushing against it.
Old 07-13-2018, 08:12 AM   #6
Jburnham54
Jburnham54's Avatar
i know that, i did this procedure 3,900 times. its bled of no problem last clutch. i wish i could send a video. my gf is doing the pumping while im under the car. i feel as the throw out isnt getting enough throw. if i can get my engagement point up off the floor a few more inches id be happy.
Old 07-13-2018, 01:19 PM   #7
Jburnham54
Jburnham54's Avatar
problems fixeds, rebuilt master cylinder and added -3an clutch line
