Old 11-08-2013, 06:58 PM   #1
ATLSS
12 Camaro 1SS
Drives: Camaro 1SS
Tunnel Brace Bolts
Anybody know the GM part number for the tunnel brace bolts or know the exact specifications on the size of these bolts? Looks like it was removed when my exhaust was done and never reinstalled. Now I have no brace and no bolts.
12 Camaro SS M6 | Cam | LT w/ HFC | Catback | Intake | Tune |
ATLSS is offline   Reply With Quote
Old 11-08-2013, 07:19 PM   #2
Bo White
Bo White's Avatar
I took mine off.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 11-08-2013, 07:32 PM   #3
ATLSS
12 Camaro 1SS
Drives: Camaro 1SS
I've read a few posted suggesting that it may jeopardize the structural integrity of the car. Just rather have it than not if possible.
Old 11-08-2013, 08:26 PM   #4
toNspahreP
Drives: SS
if you think a flimsy piece of 18ga sheet metal is going to jeopardize the structure of a unibody car...
lol
toNspahreP is offline   Reply With Quote
Old 11-08-2013, 08:46 PM   #5
toml_pa
ʇuɐıʌǝp lɐıɔos
Drives: 2011 2SS/RS LS3/M6
Bolts are 10MM-1.5
toml_pa is offline   Reply With Quote
Old 11-08-2013, 09:09 PM   #6
ATLSS
12 Camaro 1SS
Drives: Camaro 1SS
Originally Posted by toml_pa View Post
Bolts are 10MM-1.5
And the length?
Old 11-08-2013, 09:24 PM   #7
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
You can buy some aftermarket ones. If your exhaust is too jig get one with the spacers and it comes with bolts.
Sent from my DROID RAZR HD using Tapatalk
Firefighter is offline   Reply With Quote
Old 11-08-2013, 10:03 PM   #8
ATLSS
12 Camaro 1SS
Drives: Camaro 1SS
Can you please provide a link? I was thinking about getting an after market brace like BMR or Elite Engineering. Are you saying new bolts are provided??
Old 11-08-2013, 10:08 PM   #9
GMTool
MY SS is SOLD
GMTool's Avatar
Drives: AGM 2012 Camaro 2SS/RS L99
I believe the stock bolts are about 32mm long and have a smaller dia lead or shank tip. Length of threads is about 1" or 25mm and the rest of the length is the tip. The tip on the stock bolts help to align the bolt with the threaded hole.
If your exhaust is low in the tunnel brace area to where a stock brace does not have clearance, then you need spacers to lower the brace so it clears the pipes, which could mean you need a longer bolts. All depends on how low your exhaust is in that area.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
GMTool is offline   Reply With Quote
Old 11-08-2013, 10:16 PM   #10
ATLSS
12 Camaro 1SS
Drives: Camaro 1SS
Thanks for the detailed explanation. That's really gonna help if I need to go searching for these things.
Old 11-08-2013, 10:27 PM   #11
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
lol
Obviously you don't know how it works then.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 11-08-2013, 10:33 PM   #12
The Stig
knows 2 facts about ducks
The Stig's Avatar
lol
Remove yours and let me T-bone your car. Then tell me it doesn't do anything.
Seriously - why would GM spend the money on the materials and added steps during assembly if it didnt do anything? Think about it.
Click to view my build thread
Old 11-08-2013, 10:57 PM   #13
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
I've got an aftermarket one made for 3" exhaust and I had to still put spacers in and now it STILL hits. It pisses me off and I'm about to remove mine.
L99 With a Maggie
Nutro is offline   Reply With Quote
Old 11-08-2013, 11:05 PM   #14
ATLSS
12 Camaro 1SS
Drives: Camaro 1SS
Sorry to hear that man. I'm not running 3" pipe just an aftermarket 2.5 system that sits a little low. I know I gotta have something there and since my OEM on has disappeared then I might as well get after market. I just need to get the bolts.
