11-14-2013, 07:06 AM | #1 |
Drives: 2013 1LE Join Date: May 2013
9 inch or Posi mod
I'm looking to upgrade the rear diff on my 1LE. As of now I'm making 741 RWHP. I have already done solid subframe bushings, toe rods and trailing arms with rod ends. Would like to do this one time, so I wondering if the stock diff with a JRE posi mod/billet caps is going to hold up. Plan B would be a Gforce 9 inch and be done with it. Car is used mainly as a weekend toy that I can go to the drag strip every now and then. Running 275 M&H drag radial @ the moment. Thanks for any info.
11-14-2013, 07:39 AM | #2 |
220/221 whatever it takes
Drives: See sig.... Join Date: Jun 2010
IMO, do the 9 and don't look back.
Brent
2022 BMW X5 M50i 2022 Ram TRX 2021 GT500 CFHP 2016 Challenger Hellcat A8 1058whp/898wtq 1970 Chevelle SS396 4spd |
11-14-2013, 07:43 AM | #3 |
Drives: 2010 Camaro 2SS/RS,LS3 Join Date: Oct 2010
LS-3, ProCharger D1SC 665. rwhp /562. rwtq @ 9.3 psi |
11-14-2013, 08:00 AM | #4 | |
Drives: 05 GTO Join Date: Jul 2009
If you put our 9" kit in you will be done with your drivetrain mods and not have to worry about anything. In our 9" kit you will be getting a Strange 35 spline S-Trac posi unit that has a Lifetime warranty, you will also be getting our huge 35 spline inner stubs and our 31 spline Outlaw axles, all of which also come with a Lifetime warranty. If your unsure which route to go, give Chris @ Jannetty a call and he can go over which option might be best. They are a Gforce dealer so if you decide on a 9" or a posi mod, they can sell either to you. Or give me a call and I can explain more in depth on what makes our 9" kit the ultimate 9" kit on the market. Thanks Chris |
11-14-2013, 09:21 AM | #5 |
Drives: SS Join Date: Aug 2013
Auto or manual?
11-14-2013, 09:29 AM | #6 |
aka Patrick
My vote is for the 9 inch, you'll never have to worry again. I'm enjoying mine and it is worry free.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft |
11-14-2013, 10:01 AM | #7 |
Money is the factor here!!! If you can afford the 9" (or HammerHead), then by all means, do it!!! At your power level, at a bare minimum, skip the JRE Posi-Mod and at least install a Eaton True-Trac with the Billet Caps.
11-14-2013, 10:02 AM | #8 |
11-14-2013, 10:37 AM | #9 |
Thanks for the reply's. It looks like the 9 in. is the way to go. The only way I would upgrade the the stock diff is if I knew it would last. I was just going to buy aftermarket axles, but if I go with a 9 inch I will be selling them anyway. I have a DSS alu. shaft that I will have to sell too. The car only has 1,700 miles on it. LOL!!!
11-14-2013, 10:48 AM | #10 | |
11-14-2013, 11:48 AM | #11 |
11-14-2013, 12:54 PM | #12 |
11-14-2013, 02:40 PM | #13 |
WICKDSS
Drives: 2011 1SS/RS IOM LS3 Join Date: May 2010
My vote is go with the 9 inch and don't look back. I love the quietness and strength of the s trac posi in mine.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei 11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds. |
11-14-2013, 03:07 PM | #14 |
Make your peace with God!
Drives: 2011 Camaro SS/RS M6 Convertible Join Date: Dec 2011
Once you get into the level 2, you get the lifetime warranty. Then there's the level 3 with pro gears and are "indestructible". 9" is great from what I've read, but if you have the DSS axles and driveshaft, then those will bolt up to the Hammerhead.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ UNDER MAJOR OVERHAUL!! |
