Old 01-15-2019, 07:24 AM   #1
eLeSthree
Drives: 2011 Camaro SS 6sp
Ideal compression ratio for Centri setup
I cant really swing a new short block having just bought a new house and the remodeling that comes with it. So in order to crank this thing up a notch, I'm going the least expensive route, and gonna drop some pistons and rods into my stock block/crank.
I'm pretty sure I'm going with Wiseco, but I don't know what compression to shoot for.
I'm looking for a reliable weekend/street/track car that makes around 1000whp.
My options in 4.07 bore are -3.2cc and -11cc. Where will those pistons land me compression wise?
Which is most ideal for a centrifugal supercharger setup?
Since I have a tight budget, should I go with an H beam, or even a Scat I beam?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 01-15-2019, 07:51 AM   #2
hou30guy
Drives: 2011 convertible 2ss/rs
Probably some where around 10.3 to 10.5 depending on cam bleed ofd to around 10.0
Sent from my SM-N950U using Tapatalk
hou30guy is offline   Reply With Quote
Old 01-15-2019, 08:17 AM   #3
Omega
Drives: G8
What kind of fuel?
Sent from my Pixel XL using Tapatalk
Omega is offline   Reply With Quote
Old 01-15-2019, 08:22 AM   #4
eLeSthree
Originally Posted by Omega View Post
What kind of fuel?
E85. Its about 77% locally and easy to access.
1158whp 1017wtq.
630whp 658wtq
Old 01-15-2019, 06:26 PM   #5
eLeSthree
So dont give up much. Will the -3cc piston get me there?
1158whp 1017wtq.
630whp 658wtq
Old 01-15-2019, 07:46 PM   #6
Omega
Drives: G8
10.5 will be fine.
There is a little more to it than the piston dish CC. Heads and gasket thickness are two pretty big factors. A good shop will be able to make/order pistons to give you the exact CR you want rather than having you select two options that yeild a pretty substantial difference in CR.
Old 01-15-2019, 08:58 PM   #7
eLeSthree
10.5 will be fine.
Shop? You’re looking at him. I have a machinist, and a tuner, but everything else is on me. I was basing the compression off the stock ls3 head and gasket. Should have mentioned that. I figured this has been done 100 times already.
Ill find a calculator and the ls3 head specs. Thanks.
1158whp 1017wtq.
630whp 658wtq
Old 01-15-2019, 09:05 PM   #8
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Don't want to sound like a dick, but a reliable 1000 hp street /track car on a tight budget doesn't really exist.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000,
realcanuk is offline   Reply With Quote
Old 01-15-2019, 09:16 PM   #9
eLeSthree
I can accept that. Ill be happy with 900whp street car that doesnt see much track time. If it breaks, I’ll fix it. The stock motor has taken 800whp so far, so with forged pistons and rods, 900 is feasable.
I found a compression calculator. With a 4.07 bore, 4.08 gasket hole, .051 gasket thickness, 68.5cc head, 3.622 stroke, and a -3.2cc piston sticking out .005, I’ll be at 10.46. The -11cc piston yielded 9.6.
Going with -3.2cc. Thanks
1158whp 1017wtq.
630whp 658wtq
Old 01-16-2019, 10:59 AM   #10
hillshooter
Drives: 2015 Camaro SS commemorative
I have been playing with this question for 2 years. I built an engine with around 11.3:1 compression, turbo. Made stupid power on low boost and had sick midrange. Almost unbelievable power for Boost numbers, like 900HP on 12-13 pounds. Problem is I would get to the track and actually load the car and it wouldn't rev out, tons of detonation issues, tried plugs all the way to an 8 heat range, changed several fuels and eventually went to Ethanol, none of that solved it, could pull timing and get it to live but would be noticeably down on power.
This year I have a new motor I am running and it will be 10:1. of course I am convinced its going to work better but we will see!
To sum up and answer your question, I would say if I was building an application for the street and wanted to run 8-10 pounds of boost I would try for 11:1. However if you wanted to see some RPM and some serious boost like 15-20 then lower is better.
PS: LS9 gasket is .054 thick and that's what I run, also stock ls3 chamber should be 68. I have as close to a zero deck height as possible.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
hillshooter is offline   Reply With Quote
Old 01-16-2019, 01:48 PM   #11
Ajax2112
Drives: ZL1
Very good advice!!
I would go with the -11 cc. At 9.6 your in a safer area to add more boost. If your ever wanted to step up the compression a little you could always deck the heads or go with thinner gaskets to raise the compression which is a lot less work and cheaper option then having to change pistons. I have had bad experiences using thicker gaskets to lower compression.
Ajax2112 is offline   Reply With Quote
Old 01-16-2019, 03:37 PM   #12
mrimpala02
Drives: Black 2SS RS w/White Stripes
This has been discussed many times before.
From all of my research I would suggest the 10-10.5:1. I think less than that is leaving too much on the table and more than that can cause too many issues as Hillshooter pointed out.
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
Old 01-16-2019, 04:12 PM   #13
Slowhawk
Drives: 1999 Trans Am
10.5-1 is good. Most of our boost motors run that.
Slowhawk is offline   Reply With Quote
Old 01-16-2019, 04:49 PM   #14
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
My motor is 10.5-1, 3.9 stroker. Twin 76/75 CEA turbos... As hillshooter mentioned, it makes stupid power, 1200 RWHP at 12 lbs (spring pressure), 2000 RWHP at 27 lbs of boost, and we can go to 35, just haven't put all the pieces together at the track yet.... We do spin this motor to 9000 RPM.... she starts making power at 6000 rpm....
