10-27-2021, 04:20 PM | #1 |
Drives: Camaro ZL1 Join Date: Sep 2021
17x10 Weld question
I have a 2013 ZL1 and I just bought a 17x10 weld rts beadlocks for the rear. I did zip tie the E-brake line out of the way but is there anything else that I need to do for these to work? It looks like the sway bar bolt could be touching the inside of the wheel, do I need a different sway bar or end links? Thank you for any info
10-27-2021, 04:26 PM | #2 |
Drives: 2013 ZL1 Join Date: Jan 2020
Youlll want to tighten that bolt as much as possible.
Youll also want to install and spin the axle to see what else might hit. On my beadlocks I found the crossover on the caliper was rubbing. |
10-27-2021, 08:06 PM | #3 |
Drives: 2009 ZR1 Join Date: May 2010
You'll also want to see how much it squats under launch or find a way to simulate that. Just because things clear now doesn't mean they will under launch.
10-27-2021, 10:07 PM | #4 |
I’m assuming the only way to be safe is to do a 15 inch conversion even though they’re 17’s? Anyone selling a 15 inch conversion?
10-28-2021, 07:16 AM | #5 |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
BMR Suspension...formerly Carlisle Racing.
11-05-2021, 09:36 PM | #6 |
Banned
Drives: zl1 blk Join Date: Nov 2017
i took my sway bar off.... the bolt did rub because the sway bar endlink bushings were shot.
11-07-2021, 09:20 AM | #7 |
Drives: Red Jewel Camaro SS Join Date: Mar 2014
The sway bar bolt was touching just a bit at launch on mine when I was running the 17x10 Welds,had to grind it down a bit. But the season after,I changed to the BMR setup,problem solved.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
