Old 05-09-2022, 08:45 PM   #1
Heads-up
Drives: 2010 2SS
Weld Laguna 17x10_2010 ss_stock brakes
Anyone try the Weld Laguna 17x10 with the stock Brembo calipers? Initially I was told they fit and would work with a MT 305/45 17 drag radial. The local shop doing the install says the wheels rub the steel brake line coming out the bottom of the caliper.
I'd prefer to keep the better brakes rather than going through the expense and work to swap to the LT calipers. I'd send them back for a different wheel but I already bought and mounted 4 of these in the stock 20" size, so they would match.
If anyone is running any type pf 17x10 Welds can you give me the offset etc. Did you have to modify the brakes at all to get them to fit?
Heads-up is offline   Reply With Quote
