View Poll Results: RWHP estimate
525 1 4.17%
550 1 4.17%
575 6 25.00%
600 4 16.67%
625 7 29.17%
650+ 5 20.83%
Voters: 24. You may not vote on this poll
Old 09-08-2019, 11:12 PM   #1
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Estimate My Horse Power
So I'm about half way done with my build and was curious what others think I might make for power.
2014 Camaro ZL1 Manual bone stock Mustang Dyno ran 481/495 80 degree day
HP gain mods include:
BTR stage 3 PD cam with the springs and pushrods
2.5" upper pulley only
ID 850 injectors
1-7/8 Speed Engineering headers, no cats to stock NPP exhaust
Roto-fab cai with big gulp
169* thermostat
Afco HX with fans
Roto-fab intercooler reservoir 90% water
Tuned by Wong's Performance Vancouver WA
Non HP mods:
BTR V2 trunnion upgrade
New timing chain
LS2 damper
3 bolt cam gear
intercooler reinforced
ARP damper bolt
Elite catch can
Thank you and I look forward to you comments!
link to my YT channel and build videos:
Last edited by FasNuf; 09-08-2019 at 11:39 PM. Reason: link to build vids, spelling
FasNuf is offline   Reply With Quote
Old 09-08-2019, 11:22 PM   #2
d kings z28
Drives: 2014 white z28
Ask Tom about my white 2014 Z28 he Did, 535 Rwhp.headers&cats cam Heads/ 535hp.
Also did my 2014 A6 Zl1 cold air cam header &cats both pullyeys /615hp.
d kings z28 is offline   Reply With Quote
Old 09-08-2019, 11:30 PM   #3
FasNuf
FasNuf's Avatar
what mods?
Old 09-09-2019, 12:03 AM   #4
Juiced1
Drives: 2012 2SS CAMARO 45th
You should be in the 575-600rwhp I would guess. With all your mods you can run some more boost.
Juiced1 is offline   Reply With Quote
Old 09-09-2019, 05:17 AM   #5
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
my guess, it will be around 575 on that stingy mustang dyno.
tartagliazl1 is offline   Reply With Quote
Old 09-09-2019, 06:05 AM   #6
Hulk
Hulk's Avatar
Drives: 2011 Synenergy Green 2SS/RS
HP numbers your get do not matter. To much horsepower is almost not enough.
2011 Synenergy Green 2SS/RS Automatic.
Hulk is offline   Reply With Quote
Old 09-09-2019, 07:38 AM   #7
FasNuf
FasNuf's Avatar
I actually ran out of money for the project for now (just a smidge over budget ) decided to only do an upper pulley which was about $600 less than doing a lower. I also wanted to keep my blower RPM's down from max for longevity reasons. I'm running the stock LSA oil pump so too much power could be an issue I think. My understanding is the stock LSA pump is hi volume but not high pressure good to about 650rwhp. shimming the pressure relief does nothing when there's another relief in the pan for the AFM even though this car doesn't have that option. I don't want to drop the whole pan to delete that at this point.
Old 09-09-2019, 07:45 AM   #8
FasNuf
FasNuf's Avatar
I've seen others run better numbers on a Dynojet compared to the Mustang too, but my base line was on Wong's Mustang and he'll be the tuner, so the delta is what I'm interested in, not the number itself so much. only 35hp gain? wow that is stingy! LOL!
Old 09-09-2019, 11:26 AM   #9
tartagliazl1
Like juiced said you can use more boost. I did the dayco 10% lower balancer. It’s fairly cheap. I ordered it from advanced auto with there 20% off email codes. It’s a easy swap had it done in a hour.
Old 09-09-2019, 06:31 PM   #10
Shodown
Shodown's Avatar
Drives: 2014 ZL1
What's the part number on that balancer?
Back on topic, I'm guessing 600-625 HP for the OP.
Shodown is offline   Reply With Quote
Old 09-09-2019, 08:37 PM   #11
tartagliazl1
PBO1662SS10 Powerbond
Old 09-09-2019, 09:47 PM   #12
LD18SS
LD18SS's Avatar
Drives: 2013 Camaro ZL1
I'm ready to see your numbers man, been enjoying the vid's on the build. Oh by the way I got mine back today : )
LD18SS is offline   Reply With Quote
Old 09-09-2019, 10:14 PM   #13
FasNuf
FasNuf's Avatar
Thanks Larry, waiting for the pushrods to come in on Wednesday, as you saw, had to get another length for the intakes. How's the brand new blower?
Old 09-09-2019, 10:53 PM   #14
FasNuf
FasNuf's Avatar
no issue with balance or belt grooves lining up ? I see that Dayco says it doesnt fit the ZL1. (of course, not stock size) I did notice on the back of my stock damper at the hub, there is a ring on the edge, almost looks like a tone ring or mag p/u. Not sure what it is but the Dayco doesn't have it. I see it fits 09-13 ZR1 Vette. There is also a 5% version PBO1662SS5.
sorry for hijacking my own thread but the topic was only listed in one other thread.
