12-14-2018, 03:58 PM | #1 |
Drives: 2014 1SS/RS 1LE Summit White Join Date: Dec 2017
Clicking sound when taking off from a stop?
Good afternoon Everyone,
I have a 2014 1LE that I have owned for about 2 years now. I bought it from the original owner and I don't drive like a mad man. The past few months, I have been hearing some "clicking" sounds coming from the rear-end once its seems like the rear end is taking on power? The issue seems to be happening more consistently. I am thinking this may be a CV axle problem? The car only has 37k miles and is still under factory warranty. Has anyone else had this issue or have an idea on what is happening? Thanks in advance. JP |
12-15-2018, 06:14 PM | #2 |
Lusinda 2010 2SS/RS |
12-16-2018, 03:51 AM | #3 |
Drives: 2010 Camaro 2SS Join Date: Mar 2018
noise
I've had the exact same noise for 4 years nothing has happened so far yet..
12-18-2018, 03:00 AM | #4 |
Thank you for sharing! Ill probably take this info to the dealer and see if someone there has been there long enough to have seen this issue before .
12-18-2018, 07:20 AM | #5 |
Drives: 2014 SS 1LE Join Date: Apr 2014
I had a similar issue when i had a loose axle nut. Its cheap to try as they shouldnt be reused when taken off.
12-18-2018, 09:30 AM | #6 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
I registered the same problem two years ago when I got my car.
I did not pay much attention. In the morning it made a "click" and quiet all day. I was looking for a piece by number, but E-bay and Rockauto are silent. The question is, what would be the absence of a washer for a long time. Practically, it is just a matter of defining a shallow will. |
12-21-2018, 10:43 AM | #7 | |
You'll want to fix it asap. Some of us aren't so lucky and if the nut backs out too far or the inner bearing race fatigues your wheel can come off.
12-21-2018, 11:51 AM | #8 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
Someone put playing cards in your spokes
UPSTATE C5 MEMBER
