Old 09-11-2019, 08:55 PM   #1
_Onyx_Wolf_
Onyx_Z7 <— Instagram
_Onyx_Wolf_'s Avatar
Drives: 2013 2ss 1le
Stuck clutch pedal
Car has been making whining noises the past couple of days and just now the clutch pedal crashed at a red light and won’t come back up. Any ideas on what’s wrong???? Could it be the slave or master cylinder?
_Onyx_Wolf_ is offline   Reply With Quote
Old 09-11-2019, 09:49 PM   #2
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
Because it was whining for a while, I'd suspect the throw out bearing. It comes with a new slave cylinder.
Depending on the miles and how you drive the car, inspect the pressure plate, clutch disk and flywheel for wear and heat damage. Something else to consider while you have it apart, a billet bearing support for the slave cylinder.
2 places to get one, they also sell the slaves. I would suggest that you tear it apart and inspect before ordering parts that you may not need.
https://monsterclutches.com/billet-r...earing-support
https://www.tickperformance.com/tick...ave-cylinders/
EDIT: check the pilot bearing too, they're cheap and once you have everything else apart quite easy to get to. You will need a proper puller to get it out though. It's called a blind hole bearing puller.
h018871 is offline   Reply With Quote
Old 09-11-2019, 10:23 PM   #3
_Onyx_Wolf_
Thanks for the info will do
Old 09-12-2019, 04:34 PM   #4
_Onyx_Wolf_
It was the clutch master cylinder rip
Old 09-13-2019, 04:19 PM   #5
h018871
Geoff
h018871's Avatar
you mean rest in peace or the cup was ripped?
Old 09-18-2019, 08:53 AM   #6
_Onyx_Wolf_
Anyone know what this could be smh
Old 09-18-2019, 03:31 PM   #7
xc_SS/RS
Drives: 2010 Camaro SS/RS
Slave cylinder bearing support. Buy a new slave cylinder, it'll come with the throw out bearing.
If you want there are companies that make a replacement support piece from aluminum
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 09-19-2019, 04:30 PM   #8
_Onyx_Wolf_
Gotcha yeah my slave was bad just hope the clutch is okay
Old 10-17-2019, 10:26 AM   #9
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
100% replace the OE plastic throw out bearing support with a billet aftermarket piece. If you melted one, you'll melt another one. While the trans is out, definitely put a remote speed bleeder in, worth every penny when it comes time to bleed the clutch.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 10-17-2019, 10:34 AM   #10
608RS
608RS's Avatar
Drives: 2015 2ss
yup, slave went out. same thing happened to me a while back. replace and also purchase a billet sleeve, Tick Performance has them. might as well order a new slave too from them...if you haven't altready
2015 Camaro 2ss, NicKey Performance built/tuned
608RS is offline   Reply With Quote
