08-21-2021, 08:02 AM | #1 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Resonators, who is running them?
Now that I put the Stainless Works Legends on the car it is very loud in lower gears. I am thinking of adding resonators. I cannot run the Magnaflow dual in/out cause I don't want 2 xpipes in the system. I have ARH 2" into a catless ARH long system and now into the SW Legends.
So what are you running and do you like it?
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
08-21-2021, 08:13 AM | #2 |
Shadow Gray '19 ZLE M6
I haven't seen the Legends catback system, but assuming it similar to others, you wouldn't need to run two x-pipes. The magnaflow would replace your x-pipes. Cut out your current x-pipes and weld (ideally) or clamp in a magnaflow resonator.
Adding some green cats would tame it down a bit too, but I suspect you opted for catless for a reason.
2019 ZL1 1LE | M6 | SGM | PDR | CF Dash | Nav | Wheel Locks
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
08-21-2021, 08:21 AM | #3 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
I use Vibrant 1795 resonators on mine right between the Kooks green cats and AWE X-pipe.
08-21-2021, 08:51 AM | #4 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
I’m running:
2” ceramic coated Dynatech headers 3” AWE resonators Dual 3” in/out Magnaflow muffler AWE Touring mufflers Car is still not quiet...LOL. But the Magnaflow took enough of the edge off for street use.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
08-21-2021, 09:26 AM | #5 | |
Drives: 2019 ZL1 Join Date: Oct 2019
08-21-2021, 10:48 AM | #6 | |
Drives: HBM ZLE Join Date: Aug 2017
https://mbrpexhauststore.com/r1013-m...iABEgLEofD_BwE |
08-21-2021, 11:06 AM | #7 | |
Drives: 2019 ZL1 Join Date: Mar 2019
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
08-21-2021, 11:30 AM | #8 |
Drives: 2019 ZL1 1LE Join Date: Apr 2011
I have LG headers, rotafab, borla s-type cat back and e-50. I added the dual in dual out magnaflow and cut out the x-pipe from the headers, so only 1 x-pipe still. Didn’t loose any power with this set up and made the tone very nice and livable.
2019 ZL1 1LE - satin steel gray metallic M6
2009 Z06 - sold |
08-21-2021, 11:44 AM | #9 |
It’s not a true X-pipe.
08-21-2021, 12:52 PM | #10 |
At what power level are u guys at with the Magnaflow? Seems it would be to much back pressure going into a single pipe at higher hp levels? I'm at 800rwhp.
08-21-2021, 01:02 PM | #11 |
I’m lower at 663rwhp.
2009 Z06 - sold |
08-21-2021, 01:06 PM | #12 |
Don’t attempt to use that muffler at that power level. Your going to have a serious restriction.
08-21-2021, 04:39 PM | #13 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Just curious but why don’t you want two x-pipes. I have ARH headers, ARH high flow cats, ARH mid pipes with x, 2 16” MBRP resonators into AWE mid pipe with x into AWE Touring catback.
http://youtu.be/y3fxv8v2-e4 http://youtu.be/BJf08gYa1ug
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
08-21-2021, 05:44 PM | #14 | |
