11-11-2010, 08:45 PM | #1 |
Pfadt Engine Mounts
Hey guys, if anyone has the Pfadt engine mounts can you tell me how much more vibration you feel inside the car if any? I was going to buy a set, but if it increases vibration then I'll pass. I'm particularly concerned about it since my engine has a bit of a lope to it.
Thanks in advance! |
11-11-2010, 11:03 PM | #2 |
Drives: 2011 Camaro SS/ 2016 Camaro SS Join Date: Jun 2009
The Pfadt mounts can add a very small amount of vibration at idle, other than that you wouldn't feel any ill effects. With your cam you'd think it would be rougher right, it actually limits the movement and keeps everything in place. I was blown away, same car with a stock cam created more vibration. I think it keeps the engine where it is supposed to be opposed to the soft OE mounts allowing the engine to flop around. The benefits far out weight the very slight negative...
Please feel free to call, email or PM me anytime with questions! Kind regards, Jordan Priestley 888.308.6007 |
11-17-2010, 02:37 PM | #3 |
Drives: 2012 Challenger SRT8 Auto Join Date: Sep 2009
When I first put mine in I almost shat when I first started the car up, contacted Aaron Pfadt and he indicated they would quickly settle in and they did. There is a little bit more vibration at idle (and I mean very little) and if you lug it will punish you a bit more, the key is to get over the initial "holy crap it vibrates like hell" and give them a week or two to settle in. I definitely felt the improvement in how the car reacts to the throttle, no more mushy feeling. I put mine in very early on in preparation for supercharging which I haven't done yet but the mounts are ready for it
"When the people find they can vote themselves money, that will herald the end of the republic." - Benjamin Franklin LS3 Camshaft Swap Do-It-Yourself Instructions - 2010 LS3 gone but not forgotten!!! |
11-17-2010, 07:53 PM | #4 |
Drives: 2010 Camaro 2SS/RS Join Date: Jun 2009
I have had my Pfadt mounts installed for almost 8 months now and they are fantastic. They have a bit more vibration in the beginning but after they settle in they are almost unnoticeable. I would not run without them now. Very good upgrade IMHO
"We don't stop playing because we grow old; we grow old because we stop playing"
2010 2SS/RS L99-Black-658RWHP 582Tq - Magnuson TVS 2300 SC -w/OD COG LS3 Conversion - GT9 CAM - Ported Heads ADM-Race CAI - GM ZL1 Heater Hose Kit- KB BAP Kooks-1 7/8 LT Headers, Corsa-Cat-back Tune ECM & TCM - VMAX Ported TB - Posi Mod - Pfadt - Drag Coilovers, Motor mnts, Trailing Arms, Camber Plate, Control Arm Stiffeners, F&R Bushing, Pfadt ZL1 Balance/Sway bars, Sub frame, Diff bushing Nitto-NT05R DRs 315/35R20 ZL1 Prototype Wheels (10's Ft & 11s Rear) - RB Front Rotors MPD1 Spoiler |
11-17-2010, 08:02 PM | #5 | |
11-17-2010, 08:06 PM | #6 |
Do they really settle in? or do you just get used to it.......they are solid correct?
THE "MENACE"
11-18-2010, 05:16 AM | #7 | |
11-18-2010, 07:48 AM | #8 |
The definitely settle in as APEX points out they are not totally solid and the bushing probably acts more to "give a little" and as a damper but I am no engineer so that is a layman's opinion. When they first went in the vibration was very unsettling for me and I thought there was no way in hell I could leave them in there as it wasn't something I thought I could get used to. I even went ahead and pulled them out and put the stock mounts back in until I conversed with Aaron and he indicated to give them some time so I put them back in and have never looked back. The upside is I have the mount swap process down to about 25 minutes from wheels up to wheels down I've had some much practice
11-18-2010, 09:02 AM | #9 |
These come with the drag racing package, but what is the benefit of changing the mounts. I thought they would hold the engine in place more, especially cammed ones, but from what I'm reading they actually vibrate more. Or am I wrong?
Black cars are not hobbies, they are an obsession |
11-18-2010, 09:52 AM | #10 |
The engine is held in place, therefore, more vi ration is transmitted into the chassis and felt by the driver. The major benefits improved throttle response and reduced parasitic power loss but it also helps reduce the likelihood of breaking some things. For high power cars these are a must as the soft stock mounts will wear out quickly.
11-18-2010, 06:17 PM | #11 |
Drives: 2018 Charger SRT 392 F8 Green Join Date: Aug 2010
How fast do the stock motor mounts wear out? I'm looking at this mod as well.
11-18-2010, 07:11 PM | #12 |
I have not installed mine yet, but I'm going to use a nifty little app for my iPhone that measures vibration to compare before and after. Here is the stock measurement from not running through startup and idle.
*** UPDATE *** I just finished installing the mounts and all I can say is . Not only is the vibration throughout the car intense but there is more engine noise inside the cabin. I find it hard to believe these are going to settle in to the extent that they are bearable; the feel of the car went to hell with these mounts. Here is the second vibration measurement graph, you can see the vibration magnitude is approx. 4x higher Last edited by GrinderSS; 11-19-2010 at 07:07 PM. |
11-18-2010, 07:21 PM | #13 |
11-18-2010, 07:22 PM | #14 |
Similar Threads | ||||
2012 Camaro SS vs. 2012 Mustang Boss 302 Laguna Seca? | Moreno1 | Chevy Camaro vs... | 199 | 11-23-2010 04:48 PM |
Pfadt Coilovers, special CAMARO5 member PRICING of $2099!! | PfadtRacing | Suspension / Chassis / Brakes | 6 | 10-21-2010 10:47 AM |
LS3 engine specifications | Tran | Wiki | 3 | 10-06-2010 10:56 PM |
Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW | camarojoe | Dealer Camaros for Sale | 2 | 05-24-2010 05:58 PM |
Pfadt Engine Mounts installed, first and second impressions... | robertway | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 6 | 03-03-2010 09:35 AM |
