Old 05-17-2024, 10:17 PM   #1
ejv007
Drives: Chevy, Camaro
3.91 gear questions
I have been thinking about getting 3.91 gears into my M6 SS and have a few questions. Can I just get a set of gears like the ones GM offer from the 1LE and throw those in or will I have to swap/change other parts? And while I’m down there should I change anything maintenance wise?
ejv007 is offline   Reply With Quote
Old 05-18-2024, 06:29 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
If you go with the factory AAM 3.91, there is a good chance you won't need to change any shims. I'm not sure about when you go with aftermarket gears.
2010 SS - Kind of an On3 kit, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
Old 05-18-2024, 08:41 AM   #3
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Only two things I know of is you might need a shim kit and you will need a tune afterwards or your speedo and odometer both will be off.
