04-02-2016, 04:37 PM | #1 |
$1mm tip -how to remove clutch line
After unplugging the master & slave fittings there's a small plastic fastener that the line is attached to (pic 2)which holds the line to the firewall bell housing tunnel that you can remove from the firewall. You can't see the fastener so run you hand along the bottom of the line until you do feel it, then squeeze the two little prongs, it will release tension on the back of the fastener and then you can pull the fastener out with the line attached to it. Take your time and snake the line out.
04-02-2016, 08:34 PM | #2 |
i just did this but i unattached the line and popped the line out of the clip and left the clip in. doing my Ideal and tick line right now
