05-04-2021, 08:34 PM | #1 |
Drives: 2013 2SS/RS LS3 NPP Join Date: Jun 2020
Steering Wheel Bowtie Blackout Decal?
Anyone using something like this ebay item to blackout the gold bowtie on a 2013+ steering wheel? I like the idea of a vinyl decal, but the bowtie surface isn't flat, so I'm curious if this will stick for more than 10 minutes. Or is a Sharpie the best option?!
https://www.ebay.com/itm/23241698314...53.m1438.l2649 |
05-04-2021, 08:40 PM | #2 |
Or is there a way to remove the gold inlay to create a flat surface for a decal to adhere to? My car is mostly blacked out and the gold just does not fit my vibe.
05-05-2021, 04:17 AM | #3 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
I have that exact one on my steering wheel and it fit fine. The gold was tacky. I’m considering a whole new detachable steering wheel in the near future.
05-05-2021, 06:19 AM | #4 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
I used plastidip, same as my front bowtie, just taped it off well.
05-05-2021, 10:28 PM | #5 |
Drives: Camaro Convertible 2014 1LT Join Date: May 2019
Yup, I also bought a vinyl decal and used a blow dryer to heat it to the surface and the rough surface actually grab the decal nicely.
05-06-2021, 07:50 AM | #6 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
I used vinyl and my heat gun, then an exacto knife to trim it out.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
