Old 11-21-2020, 01:25 PM   #1
2016scatpack
Drives: sdfgsgbfgbrgb
1le gearing
I purchased a 2013 1le that is cammed and has a twin turbo kit. I know the stock rear is the stock 3.91. Im trying to figure out if my car has odd transmission gearing. Im at 2500ish rpms at 80mph with stock tire height. that seems high to me compared to all other ls powered vehicles ive owned. I know the 1le has difference gearing vs a stock SS. I cant seem to find any info on how difference the geariung is or if my car has something else down to it.
thanks
2016scatpack is offline   Reply With Quote
Old 11-21-2020, 01:43 PM   #2
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 Z/28 ‘14 ZL1 M6 vert
This compares the trans gearing
SIM GhostrdrZ is offline   Reply With Quote
Old 11-21-2020, 02:45 PM   #3
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
It seems to me or if I change the final ratio from 1LE to SS, I get a better transfer than 1LE ..?
George-CZ is offline   Reply With Quote
Old 11-21-2020, 02:51 PM   #4
SIM GhostrdrZ
You didn’t ask but;
Here’s Z28 gearing as well if it helps.
Old 11-21-2020, 10:23 PM   #5
2016scatpack
Originally Posted by SIM GhostrdrZ View Post
You didn’t ask but;
Thanks, i highly doubt i have a .5 overdrive. I wonder if it was swapped at somepoint. 2500 at 80 seems way tlo high.
Old 11-22-2020, 05:58 AM   #6
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
80 mph is ~2000rpm
CamaroDreams76 is online now   Reply With Quote
Old 11-22-2020, 10:33 AM   #7
2016scatpack
Originally Posted by CamaroDreams76 View Post
80 mph is ~2000rpm
Gotcha, im 500rpms higher than that with the stock 3.91
Old 11-22-2020, 11:16 AM   #8
SIM GhostrdrZ
Is that in 6th gear?
Old 11-22-2020, 11:27 AM   #9
SIM GhostrdrZ
This calculation is in 6th gear @ .5 if trans is stock
Old 11-23-2020, 12:02 AM   #10
Billy10mm
Billy10mm's Avatar
Drives: 2014 Camaro 2SS 1LE NPP
2K RPM in 6th should be 84 mph on a stock 2013 1LE.
Either you are NOT running stock tire height, or someone swapped out your rear gear for something a bit shorter.
My thoughts on some things:
  • Driving Nannies: If I'm that far out of shape on the street, something has gone terribly wrong and by all means Mr. Computer man, come and get me.
  • G2s: Rock throwing is like like a tramp stamp; although problematic, it's a sign of good things to come.
Billy10mm is offline   Reply With Quote
Old 11-23-2020, 06:10 AM   #11
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Have you checked the accuracy of your speedometer to your actual speed? My tuner was able to adjust mine to my smaller diameter wheels.
Just a thought.
Sent from my Pixel XL using Tapatalk
Old 11-23-2020, 03:53 PM   #12
2016scatpack
I verified the stock gear in the diff and the wheel and tire height is correct. 1st through 4th seem normalish. 5th and 6th seem to only drop the rpms 500ish. Im gonna check it out next time i drive it. Im wonder if someone eithrr swapped the trans or altered the gear aet in it.
QUOTE=larry_g;10906909]Have you checked the accuracy of your speedometer to your actual speed? My tuner was able to adjust mine to my smaller diameter wheels.
Just a thought.
Sent from my Pixel XL using Tapatalk[/QUOTE]
Speedo matches my gps.
Old 11-23-2020, 04:52 PM   #13
CamaroDreams76
5th and 6th definitely drop more than 500 rpm. Im thinking someone changed the gears in the trans. Maybe it was a half mile car or someone didn't like having 5th and 6th usless for top speed runs?
Old 11-23-2020, 06:06 PM   #14
2016scatpack
Im gonna check the speed at 3000rpms tomorrow in each gear. Im guessing the changed the gears in the trans for road courae because its revving so high in 6th. Im guessing i will be at 90 or 95 at 3000rpms, so im guessing the car will top out in the 180 or 190 range gear wise. The previous owner didnt touch the trans, he just did the turbo kit
