08-25-2009, 10:31 AM | #1 |
Drives: SIM 2LT Camaro RS Join Date: Apr 2009
Tire Monitoring System issue
My tire monitoring system is acting crazy. Its saying I have low tire pressure on the right passenger side (31 according to the car) but when I checked the pressure manually it says 37. After I put air in the tire anyway and reset the computer, the damn thing is telling me now to service the Tire Monitoring System. So I get to work and tell my co-worker who owners a 2010 Camaro SS and he said he is having the same problem. Needless to say I'm taking it to the dealer to have it looked at but AFTER I get my free pizza from Papa John's tomorrow (lol).
Is anyone else experiencing this problem?
08-25-2009, 10:48 AM | #2 |
Resident Engineer
Drives: 2010 Camaro SS, 1988 GMC S-15 Join Date: Jun 2009
did you try resetting the monitors on the tires? there's a pattern in which you let out air of each tire, then refill to reset...should be in the manual
12.68 @ 109: LSR cai, Borla S-type axle-back, Tunes |
08-25-2009, 11:01 AM | #3 |
Drives: 2019 Corvette GS, 2023 ZL1 Join Date: Mar 2009
Yep, I'm having this same issue. Actual tire pressure is just fine - but the monitor indicates 30-32 psi - all tires. I have about 950 miles on it, so I was going to just wait and get it looked at when I get the oil changed after 1000 miles.
I did reset the system - but that didnt work. I'll check out the manual tonight.
08-25-2009, 11:33 AM | #4 |
Drives: Jet Black Camaro-white racing Join Date: Aug 2009
TPMS sensors area a waste of time and money, just another way to pull money out of the consumer... I've always hated them...
08-25-2009, 11:53 AM | #5 |
susp.ban4life!
Drives: Raptor Join Date: Jun 2009
This is a big enough issue that GM has issued several TSB's on. I have been having issues since day one. The bad thing, is GM wants ONLY certain of these problems covered under warranty. If your TPS flashes for a minute or so when the key is turned on THEN just stays on your ok. But they are finding out if someone is syncing there tires near another car with tire sensors it likely will foul the others sensors. GM does not want to pay for those types of sensor problems. The first type requires going into the CPU. The TPS are in the door lock regulator program. You have to go in there to look for codes. If there are codes, they must be reset then the tires relearned. If the sensor then continues to set off, it is determined to be a warranty issue.
08-25-2009, 11:56 AM | #6 |
susp.ban4life!
BTW, If you have a custom tune and are worried about losing it if they go in there, it should not be a problem. Just make sure they don't reflash the entire PCM. (THAT THEY STAY IN THE DOOR LOCK PROGRAM)
08-25-2009, 11:58 AM | #7 |
Drives: SBM 09 G8 GT/RH 15 SS 1LE Join Date: Apr 2009
Mine has been acting up on my G8 as well!
08-25-2009, 11:58 AM | #8 |
Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
there is a bcm update for tire pressure monitor,, have your dealer update your bcm
08-25-2009, 12:22 PM | #9 |
Camaro SL,UTs
Drives: 2010 Camaro SS/RS #16429 Join Date: Sep 2006
I know that if I corner really hard and fast in my 2008 HHR SS I get the light stating that there is a problem with TPMS. But after I turn the car off then back on again it's gone. I really can't recreate it at the dealership unless one of their techs comes with me and I scare the **** out of him on a corner. No problems on my 2010 Camaro SS yet......
08-25-2009, 01:29 PM | #10 |
It has to be a GM thing because come to think about it, my 2001 Monte Carlo (May it R.I.P.) had TPMS problems too. But of course it started acting up AFTER the warrenty expired.
@ Camaro1 - Have no idea what a bcm is but I will surely mention that to them. thx
08-25-2009, 03:50 PM | #11 |
Drives: '10 Camaro SS Join Date: Apr 2009
Might want to take the wheel off and submerge it in soapy water and look for a bad aluminum cast wheel like i had.
Here is the thread. http://www.camaro5.com/forums/showth...839#post842839
2010, SIM, 2SS/RS, LS3, CGM Stripes
08-25-2009, 06:31 PM | #12 |
Drives: 21 LT1 RS M6 in SSM Join Date: Jul 2009
Don't have my Camaro yet, but the TPMS in my 2007 Mazda 3 worked great.
I think the TPMS is a government-mandated thing starting with a certain year--2008. "Improper tire inflation kills! We want you to be safe! Your car will now tell you when you are low. Big Brother is watching....your tire pressure!" Rob |
08-25-2009, 08:52 PM | #13 | |
Drives: 2010 Camaro 2SS RJT Join Date: Apr 2009
2SS RJT A6 Sunroof Polished Wheels. Delivered 5-22-09 by Classic Chevrolet Sugarland
08-25-2009, 08:54 PM | #14 | |
Similar Threads | ||||
Vararam Ram air system for V-8 and V-6 2010 Camaro | sales@vararam.com | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 133 | 02-21-2013 09:25 PM |
WHAT A NIGHTMARE!!! | TAG UR IT | 5th Gen Camaro SS LS LT General Discussions | 110 | 09-27-2009 11:25 AM |
How does onstar know what tire pressure I have? | FLYNNZL1 | Wheels and Tires Talk Sponsored by The Tire Rack | 8 | 08-09-2009 02:11 PM |
2SS/RS CGM man... | GTAHVIT | Camaro Price | Ordering | Tracking | Dealers Discussions | 36 | 08-01-2009 06:03 PM |
Resetting TPMS Tire Pressure System | jvmax | Wheels and Tires Talk Sponsored by The Tire Rack | 4 | 07-10-2009 12:37 AM |
