10-16-2018, 11:16 AM | #1 |
Drives: 2010 2SS/Black Join Date: Mar 2009
Engine Cleaning
All,
I live in a dusty climate (AZ) and was looking for suggestions on cleaning the engine. Back in the old day I would spray the engine with Gunk and take it to a "do it yourself" wash to rinse the engine but not sure if this is still acceptable.
2010 Black 2SS L99
Mods: * CAI Intake * Magnuson MP2300 TVS Supercharger/RDS Spacer * Vector Motorsports Tune * Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series * R1 Concepts ceramic pads and slotted/drilled rotors |
10-16-2018, 11:33 AM | #2 |
Drives: 2011 2SS Join Date: Mar 2015
If your car is stock under the hood, typically on new cars you’d be okay to get it wet but I know many people are still weary of doing that, so you can get a degreaser to get most of the gunk off of its really dirty, brushes help to get in the smaller areas. Then you can use some trim shine (or interior detailer if you’re in a pinch) to clean all the blacks and a normal quick detailer for everything else
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears |
10-16-2018, 12:04 PM | #3 |
Drives: 2014 Camaro 2SS RS & Ground effects Join Date: Apr 2014
Missile Man Here is what I do. While the engine is cold I spray the entire engine down, then I use soapy water and a sponge, after cleaning I rinse it down. I dry it off as much as I can with a shammy and let the rest air dry. Make sure it is totally dry before starting it or you will through black water from the fly wheel and belts everywhere. Hope that helps.
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 |
10-16-2018, 03:33 PM | #4 |
Drives: Camaro V6 Join Date: Oct 2016
Never do it with the engine cold. At least have the engine warm which will make the degreaser work better. However, if it's just dirt and dust, a simple rinse down may be enough. Then, drive it around a little bit to evaporate the rest of the water from all the nooks and crannies in the engine compartment.
10-16-2018, 09:36 PM | #5 | |
10-17-2018, 08:31 AM | #6 |
Thanks for all the feedback!
2010 Black 2SS L99
10-17-2018, 08:59 AM | #7 |
Drives: 1991 Z/28 Convertible Join Date: Feb 2018
I use Purple Power. Spray it on and let it sit for about 20 to 30 minutes and then spray it off.
10-17-2018, 09:04 AM | #8 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I saw this on one of the car tv shows lately. Haven't used it so can't recommend, but it might be worth looking at.
https://www.mckees37.com/engine-kit.html# |
10-17-2018, 09:12 AM | #9 | |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Here's what I do for my customers: vacuum engine bay clean with Meguiar's All Purpose cleaner and black microfiber towel wipe the rubber with Duragloss 265 Ultimate Detail Spray condition the plastic parts and trim with Mothers Back to Black It is fine to spray a garden hose (no pressure) on any car engine made later than 1995. I use a hose if the engine is really bad.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
10-22-2018, 01:08 AM | #10 |
Drives: Supercharged 2013 AGM 2SS/RS Join Date: Oct 2013
Personally I avoid using a hose in the engine bay. You shouldn't need it if you're just dealing with dust. Waterless wash, some MF towels, and finish off with Adams In & Out and Chemical Guys VRT.
Here's a thread on it, including my before/after pics: https://www.camaro5.com/forums/showthread.php?t=520927
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports. 1967 Bolero Red 396 SS/RS Convertible |
10-22-2018, 08:59 AM | #11 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
After almost 10 years my engine bay still looks like new. I only clean what can be seen. I use Simple Green on the W/hsgs, shock towers, cowl vent, air cleaner, fuse box, radiator tie bar and inner fender components. I use a small soft paint brush and then a light spray rinse gets it clean.
10-28-2018, 12:04 PM | #12 | |
10-28-2018, 06:20 PM | #13 |
Like I said, I clean and detail what can be seen. It's a driver.
10-29-2018, 02:32 PM | #14 | |
Drives: The shiny ones. Join Date: Mar 2010
Here is some good info...…
