10-30-2014, 11:27 AM | #1 |
Drives: 14 RedLRockMetallic ConvertV6 2ltRS Join Date: Sep 2014
Best product to remove sticky stuff
I have a grayish spot on my vinyl trim (see pics) it is slightly sticky. I tried a damp microfiber cloth & it didn't help. I tried a little Sprayway Glass Cleaner on microfiber & it didn't help.
I don't want to ruin the finish so I thought I'd check wit the experts here. Thanks ! |
10-30-2014, 11:28 AM | #2 |
Sorry I'm having trouble uploading pictures but appreciate help
10-30-2014, 11:31 AM | #3 |
VroomVroom
Drives: 2017 50th 2SS Join Date: Apr 2012
not sure about it being sticky, but Adam's Super VRT works great for marks on vinyl and plastic.
2017 H50 2SS MX8 F55 NPP CF5 RN2
10-30-2014, 11:36 AM | #4 |
Try a little goof off stain and adhesive remover....might do the trick...
Sent from my XT1058 using Tapatalk |
10-30-2014, 11:37 AM | #5 |
10-30-2014, 11:38 AM | #6 |
10-30-2014, 11:44 AM | #7 |
Drives: 2010 Camaro 2SS/RS LS3 Join Date: Oct 2013
Simple green works very well, goof off works also but I would be a little concerned about discoloring the area
Hurst Short Throw Shifter, K&N CAI, SRP Racing Pedals, GM Performance Exhaust, GM GFX Package
Lakewood Strut Tower Brace, JBA Shorty Headers, JBA 8 MM Wires, Airaid TB Spacer, Phastek CAI Scoop, Washer Bottle Relocation Kit, Stainlees Steel Brake Lines, Brake Performance Slotted and Drilled Rotors, BMR Tunnel Brace, BMR Trailing Arms, BMR Subframe Connectors, Borla ATAK Muffelers, Z28 Wickerbill Spoiler, VTC, Bow Tie Delete, BMR Adjustable Front Swaybar, BMR End Link Kit, BMR Extreme Rear Anti-Roll Kit, Diablo I1000 "InTune" |
10-30-2014, 11:45 AM | #8 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
No shortage of cheap plastic on these cars. Try a little in an inconspicuous place first.
10-30-2014, 11:48 AM | #9 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
By no means am I one of the experts but, I have had good luck with denatured alcohol. It's relatively safe. I would still test an inconspicuous area first though.
Sent from my SM-G900V using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
10-30-2014, 12:22 PM | #10 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
303 aerospace or any trim cleaner/restorer would work well.
10-30-2014, 01:53 PM | #11 |
This stuff worked thanks all !
Used white microfiber Had to press harder than I wanted No discoloration or marks. Perfect |
11-03-2014, 12:58 PM | #12 |
Glad it worked brother.....
11-05-2014, 11:17 AM | #13 |
Drives: 2010 2SS/RS Join Date: Apr 2011
WD-40. Stuff works on anything. Eats away the adhesive and won't damage the surface. For the future lol
11-05-2014, 03:14 PM | #14 |
Drives: 2011 Camaro LS Join Date: Jan 2012
3M adhesive remover. It's a white can with red lettering and can be found at local auto parts stores
