06-09-2018, 02:44 PM | #1 |
Drives: 2014 LS RIP Join Date: Sep 2017
2014 2LT needs a new rack
Quite disappointing to all of a sudden hear my power steering pump start whining like a Ford only to see a bunch of crap right at the input shaft on the rack. Has anyone else had this issue?
06-09-2018, 04:54 PM | #2 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Wow. How many miles are on your 14?
06-09-2018, 09:56 PM | #3 |
112
06-10-2018, 01:43 AM | #4 |
Drives: Camaro V6 Join Date: Oct 2016
Makes me wonder if we should be flushing the fluid out of the power steering rack as a regular preventive maintenance procedure.
06-10-2018, 09:28 PM | #5 |
I can’t really say until I pull out mine and see why it really failed. Rather frustrating on a 4 year old car!
06-11-2018, 08:28 AM | #6 |
Drives: 2012 Camaro LS V6 Join Date: Aug 2016
06-11-2018, 07:38 PM | #7 |
Yes and yes. However you would think GM would still use quality parts that would stand up to that kind of use. Everything here in Maine are highway miles
07-02-2018, 12:41 PM | #8 |
Drives: 2012 2LT/RS Join Date: Oct 2011
It's not that insane, 25k/year is common among sales folks or others with long commutes. Now, if it was a taxi and doing lots of turning, I would say the rack and pump don't owe you much if at all However, can we assume it's mostly highway miles? If so, 4 years on a rack is pretty bad, though it's possible it's the pump that's spewing bits into the rack and what's caused the issue. Sadly, I think the pumps on these cars weren't great right from the start.
