02-20-2019, 09:15 PM | #1 |
Drives: 2015 Camaro 2SS/RS Join Date: Jan 2007
Keyfobs stopped working 2015 SS
Keyfob worked while leaving work. Got home and now the car does not respond to fob commands.
-Changed Battery in fob and still did not work. -Tried my spare key fob which did not work either (changed battery too) What shall I try next? RKE or BCM?? Where are they located and is it hard to change? Thanks!
2015 2SS/RS 6spd
Rotofab CAI,MGW Shifter, DSP Tune Kooks LT/HFC/Xpipe/NPP Mufflers 4:10's, Trutrac Solid Cradle Bushings, BMR Toe and Trailing arms |
02-21-2019, 12:54 PM | #2 | |
EMERALD COAST CAMAROS
Drives: None Join Date: Feb 2010
02-21-2019, 02:36 PM | #3 |
Drives: 2011 2SS/RS Join Date: Feb 2016
If you put an LED bulb in the dome light, take it out. Caused mine to refuse communication
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
02-21-2019, 03:27 PM | #4 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
LED bulbs are screwing up lots of stuff. My Homelink won't work if I back in my driveway.
