04-19-2015, 10:43 PM | #1 |
Titanium lug nuts and wheel studs?
Anyone interested in a titanium lug nut and wheel stud kit? the nuts alone do not save much weight like the studs also would do.
We are planing on making them. |
04-20-2015, 08:53 AM | #2 |
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
What is the estimated weight savings over stock with a full stud/nut setup? And the corresponding weight reduction to my wallet?
04-20-2015, 09:28 AM | #3 |
Drives: 2013 ZL1 Join Date: Nov 2013
Price?
04-20-2015, 10:44 AM | #4 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Let me know the price?
04-20-2015, 10:59 AM | #5 |
Drives: '14 1LE Join Date: Nov 2013
Interested if the price is right
11-16-2019, 08:57 AM | #6 |
Drives: Camaro Z/28 - 2015 Join Date: Sep 2019
What has become of this project?
11-16-2019, 05:14 PM | #7 |
Drives: 2015 Camaro Z/28 #311 Join Date: Feb 2018
Aluminum lug nuts
I have been using hardened aluminum lug nuts for 3 years now and have had no problems with stripping or lugs coming loose. I have saved almost 5 Lbs. That's over a pound a wheel.
11-16-2019, 08:53 PM | #8 |
I thought so too. The idea of Skylane765, also the studs in Titanium, I would also like to do. But I have not found a company that offers pressed studs in Titanium.
11-16-2019, 10:24 PM | #9 |
Raging Bull Reborn
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631 Join Date: Mar 2012
Are the rotors a steel center? If so how do you propose countering galvanic corrosion on those pressed in studs? I’ve done years of corrosion work in designing oilfield coatings here in Oklahoma...and studs slowly corroding after being pressed in could lead to catastrophic failure.
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631 Toy 2 '09 CGM Z06 3LZ My DD: '17 Ford Mustang GT Her DD: '14 F150 Ecoboost 3.5 |
11-17-2019, 09:16 AM | #10 | |
'It's an experiment'
-Don
747 RWHP 794 RWTQ
11-17-2019, 01:20 PM | #11 | |
Therefore I would replace the steel studs with titanium studs, but I do not know who offers pressed titanium studs. |
11-17-2019, 02:11 PM | #12 |
Drives: '15 Z/28 #0270 Join Date: Jan 2017
Titanium lug nuts made by the OP
https://zl1addons.com/collections/ca...ro-and-mustang Titanium lug nuts made in California https://ozmoengineering.com/shop/m14...nical-lugnuts/ Haven't found wheel studs yet. |
11-19-2019, 08:29 AM | #13 |
Raging Bull Reborn
That’s why I asked - the rotor structure is steel, pressing Ti lugs into that WILL cause galvanic corrosion, at the steel-titanium interface..you need an anti corrosive on the Ti lugs to prevent the inevitable corrosion. Potentially a passivation coating that is applied via a flame ionization might work,for a perfect product.
11-20-2019, 11:53 PM | #14 | |
Okay, thanks. And how about the connection between the oem studs and titanium lug nuts - are there any problems? |
