11-10-2019, 08:27 PM | #1 |
Drives: 2010 2SS/RS Centennial Indy edition Join Date: Dec 2013
SCT 3416
Hello to all. I have been a member for quite a while,but have not been on here until recently. Anyway about 4-5 years ago i purchased from a member a 391 diff and axles from a low mile 1LE. At that time I also purchased a SCT tuner that had been converted to a 3416. I only got the tuner to reset gear ratio for the 391 gears. At that time not even the dealerships were doing this. When I received the tuner and paperwork from SCT I plugged it into my car. It came on and I believe said unmarried. That was all I did with it. Unplugged and put back in the box. Well life happened and all of these parts have been sitting in my house waiting to be put in. That is finally happening in the next 2 weeks. As far as the tuner goes will I need/should update it? Is this model still supported by SCT? I was also hoping to be able to shut off the AFM with this tuner. Thanks in advance Bill.
11-10-2019, 08:40 PM | #2 |
I guess I should also say that my car is a 2010 L99. Also I have a vitesse throttle controller. Will I need to remove this before using the SCT?
11-11-2019, 05:31 PM | #3 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
I believe you can go to the sct website and update the device.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
12-09-2019, 09:17 AM | #4 | |
No need to update the device that would only be the preloaded tune side not the custom tune side. Yes remove the Vitese controller . Ted.
www.jannettyracing.com
