09-25-2018, 04:13 AM | #1 |
Drives: 2015 2SS/1LE Join Date: Sep 2018
Chassis Braces
Does anyone make a chassis brace for 2015 SS. I'm looking for something like http://unibrace.com/products/ for example. I have one of these on my 2011 Golf GTI and it makes a world of difference.
09-25-2018, 05:57 AM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
Some will argue that such a brace is not required to stiffen up the fifth gen Camaro, and instead opt for solid rear subframe bushings such as the ones from Pegasus as they are much lighter but also stiffen up the rear end so much that it feels like a whole new car. However, if you do want a brace there are a few companies that make them.
09-25-2018, 06:56 AM | #3 |
Drives: 2010 Camaro SS Join Date: Jul 2018
I was looking at some from BMR last night
2010 2SS/RS 6M, MGW flatstick, CAI cold air intake, SLP loudmouth 2 axleback, TSP 1 7/8 headers w/ hfc, pfadt 1" springs, SRP pedals, emblempros "6.2L" emblems on hood, ZL1 grill, M/T SC-5 wheels, nitto motivo 275f 315r. ZL1 addons wickerbill, smoked lenses, resonator delete x pipe, diode dynamics DRLs 1LE suede steering wheel, mighty mouse CC. SCTX4 and Dyno Steve tune.
09-25-2018, 06:58 AM | #4 |
Drives: 1991 Z/28 Convertible Join Date: Feb 2018
Have you tried Summit Racing?
09-25-2018, 09:22 AM | #5 | ||
'It's an experiment'
https://www.summitracing.com/tx/part...ort-suspension
https://www.hotchkis.net/product/201...sis-max-brace/ Install: I use this one -Don
747 RWHP 794 RWTQ
09-25-2018, 10:31 AM | #6 |
Drives: Race Car Join Date: Sep 2009
Cradle Bushings will give you a lot more bang for the buck vs Subframe Connectors 5th Gens
09-25-2018, 11:00 AM | #7 |
Yep solids would be the way to go..
I have the brace and solids... My brace also protects my aux fuel system.. -Don
747 RWHP 794 RWTQ
09-25-2018, 11:50 AM | #8 |
Drives: 2010 2SS/RS Join Date: Dec 2009
If you look at the video the cradle still moves a little bit but install one of the many solid cradle bushing sets and that stops with no increase in NVH!!!
Orange Krush II
10-18-2018, 02:36 PM | #9 |
Drives: 2010 SS L99 Join Date: Sep 2018
Go solid subframe bushings, they work great! You can find them here:
http://www.jdpmotorsports.com/pegasu...maro-peg-r-cb1 Also, see my post for DIY, i include tools/sizes needed, full instructions, an instruction video with quality, and a spec table: https://www.camaro5.com/forums/showthread.php?t=540578 Hope this helps!
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
10-18-2018, 05:56 PM | #10 |
I have a Sphon front chassis brace that I'm gonna remove if your interested in something like that?
Orange Krush II
