Old 04-27-2017, 08:12 PM   #1
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
Pulled Onstar Module...
Gave me a stabilitrack error on start, and cannot use the suspension modes... the tour and sport lights are out.
Just wanted to see how car responded with it out...
Still have blue tooth music, car connects to the phone for phone conversations and they can be heard through the speakers but you cannot talk to people.
Still have navigation (shows me my current location, didnt go for a drive yet) xm preview(no sub here), and am/fm
Going to open it up and pull the comm bridge out, reinstall it ... see if i can get my suspension modes back.
Crash76 is offline   Reply With Quote
Old 04-27-2017, 09:52 PM   #2
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Mods:
Old 04-27-2017, 11:04 PM   #3
Crash76
Team 913
Old 04-27-2017, 11:08 PM   #4
Crash76
Team 913
The small bridge connects the main board with the small board (antenna) still in the case...
I plan on leaving that out per some other instructions and seeing if everything works again.
I find it poopy that the onstar box knows / plays a roll in my PTM settings...
Hopefully i will stop receiving emails about my car from onstar
Old 04-27-2017, 11:57 PM   #5
derklug1
derklug1's Avatar
Drives: 2016 GT350
The Onstar module doesn't know what your settings are, but it is often a pass-through for the CAN line(the data link that connects the various modules). When the module is removed, any downstream module is cut off from the network. I don't have a diagram on me, but if you get one, you should be able to create a jumper for the CAN lines.
"Life is hard, it's harder if you're stupid" John Wayne
derklug1 is offline   Reply With Quote
Old 04-28-2017, 12:35 AM   #6
Crash76
Team 913
I plan on plugging everything back in without the antenna bridge... hopefully that works, find out when i get off work in the morning
Old 04-28-2017, 12:36 AM   #7
Crash76
Team 913
Thanks for the info
Old 04-28-2017, 05:28 PM   #8
Crash76
Team 913
Put the box back in minus the bridge... PTM modes and setting back... no stabilitrack warnings...
BT Audio Works, Nav Works, Still cannot use the mic for voice phone calls, which is fine...
All is well
Old 04-28-2017, 05:41 PM   #9
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
All is well
Sounds interesting.
Is there a way to may the mic work for phone calls?
Mods:
Old 04-28-2017, 06:38 PM   #10
cowmaro
Drives: 2012 M6 ZL1
Was this a weight reduction mod or did you want 'big brother' to not see you doing a buck fifty?
cowmaro is offline   Reply With Quote
Old 04-28-2017, 06:46 PM   #11
Crash76
Team 913
Sorry, bad info about the mic... it works, i just went out and tried it. There is a red icon (circle with line through onstar symbole) now on the rearview mirror.
Here is link to where i got the info on how to disable onstar
http://www.instructables.com/id/2014...isable-OnStar/
Old 04-28-2017, 06:50 PM   #12
Crash76
Team 913
So to summerize, nav screen seems to track (again i havent driven yet, shows up where im parked at the house), xm radio preview works, am/fm/bluetooth radio works, blurtooth/hands free phone works.... No codes or warning on startup...
Hope this helps
T15 torx for the panel under the glove box, T10 torx to take the cover off onstar box
Old 04-28-2017, 08:16 PM   #13
Crash76
Team 913
No not weight reduction... that box is not even a lb... and you have to reinstall it.
i take my car to road courses, only time i really speed around town is when im testing a tune and data logging or burnishing brakes... and that is all on back roads... mainly dont need a company tracking my car data... wether its monthly diagnostic info / tire pressures / oil life... etc
Just a personal preference...
Old 04-28-2017, 08:31 PM   #14
chuckie669
chuckie669's Avatar
Drives: 2011 ss
Wish you were closer. I've pulled the boxes out of my previous cars but that was before Bluetooth
chuckie669 is offline   Reply With Quote
