11-26-2015, 10:29 AM | #1 |
Drives: Camaro Join Date: Oct 2015
Headers cats\no cats
I have a pretty much stock 2011 SS with an eforce. Power wise I'm pretty happy with it. Throttle response and drivability I think could be better.
My plan was to get the fuel system up to snuff. I picked up a ZL1 pump and ID 850 injectors Was going to do the ADM, rotofab and a one step smaller pulley. Dyno tune it and call it good. I'm reading that headers maybe needed for what I'm looking for and that more importantly the stock cats are a potential hazard in an FI car. And that no cats is the way to go. Any experience with this from you guys running FI? |
11-26-2015, 02:04 PM | #2 | |
Drives: 11 AGP TT SS, 14 ECS C7 Join Date: May 2012
TSP has really nice headers & mid pipes, if you start comparing companys & prices you will see it's probably the best bang for the buck. Good luck with the build & have a happy thanksgiving! |
11-26-2015, 04:29 PM | #3 |
Drives: 2011 L99 SS Join Date: Oct 2014
No cats here.
11-30-2015, 03:35 PM | #4 |
just ordered my headers and decided against cats because of what was said about re: melting the hi-flow cats.
11-30-2015, 08:44 PM | #5 |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
I think 2" headers are at the end of the max of this style of super chargers. I think 1 &7/8 will be fine
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
12-01-2015, 06:01 AM | #6 | |
http://www.camaro5.com/forums/showthread.php?t=63640 |
