Old 10-30-2018, 09:21 PM   #1
Royal Tiger
Drives: 2013 2SS/RS Convertible
Good aftermarket stock height springs?
I just installed Koni yellow shocks & struts with 1” BMR lowering springs and with my wide tires (275/40 front & 315/35 rear) I needed to add 5mm spacers to stop the front tires from rubbing on the struts. Now the fender lip is rubbing the outside of the front tires and the ride overall is pretty hard. Basically, wife flat out hates how it rode today in the first real trip we took with it. What springs can I get to go back to stock height? Everything I’m finding is to lower it. I ditched the old springs and would like something better than OEM, but have that kind of ride and get back the clearance I had before. Thanks.
Royal Tiger is offline   Reply With Quote
Old 11-01-2018, 09:24 PM   #2
Royal Tiger
Nobody??
I guess I’ll be ordering some OEM springs. They should mate with the Koni’s correct?
Thanks.
Old 11-01-2018, 10:17 PM   #3
derieu
Engineer
derieu's Avatar
Drives: 2014 Camaro 2SS RS 1LE
Z28 OEM Springs
2014 Red Hot Camaro 2SS RS 1LE
-Sunroof Delete, Recaro, Nav, NPP
-Pegasus Subframe Bushings, JPSS Radius Insert, Detroit Speed Caster Mod, PMAS Intake, Solo High Flow Cats, Ecsta PS91 Tires, MGW Shifter, Pegasus Offset Poly Diff Bushing
derieu is offline   Reply With Quote
Old 11-02-2018, 06:39 PM   #4
Royal Tiger
Originally Posted by derieu View Post
Z28 OEM Springs
Thanks for the reply. Are they close to the factory SS height?
Old 11-05-2018, 01:58 AM   #5
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
I'd trade you my stock ones if you weren't 1000 miles away
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 11-05-2018, 06:34 AM   #6
Royal Tiger
Thanks Rebel.
Old 11-05-2018, 02:20 PM   #7
derieu
Engineer
derieu's Avatar
Maybe a hair lower if that, they will go well with your current shocks
Old 11-05-2018, 04:54 PM   #8
Royal Tiger
Thank you.
