Old 01-28-2014, 07:30 AM   #1
13BlackOut21
13BlackOut21's Avatar
Drives: 13 Chevy Camaro LT
Exclamation HELP! Blue spray paint can exploded in the garage!!
I had a blue spray paint can explode in the garage the other day and I didn't think anything of it till I went to detail the Camaro and my wife car the other day! It honestly looks like my car has blue metal flake in it! (Both cars are black) Its not bad but when you get up on the car you can see it or when you look at the hood at a very steep angle you can tell it looks like there is blue dust all over the hood...
What do I do!!!
I've read many things from using chemicals to get it off then waxing it.
I've also read about wet sanding it then waxing it.
I've done everything mechanically inclined with vehicles except for body/paint work? Is this something I can do or pay for a professional to do it?
Note: All chemicals/Aerosol cans are now in a cabinet.
Live Everyday Like It's Your Last!
13BlackOut21 is offline   Reply With Quote
Old 01-28-2014, 07:41 AM   #2
SSTG
Drives: 2014 Z51 Corvette
Try using a Clay bar. That will remove fresh light overspray.
SSTG is offline   Reply With Quote
Old 01-28-2014, 07:42 AM   #3
CruznSS
CruznSS's Avatar
Drives: 2SS/RS Camaro ABM - Silver Ralleys
I'd try porta-cable & fine swirl remover. Contact Junkman from Adam's Polishes. Always best for advice from an expert. Good luck. Pics might get ya some better feedback.
Sent from my SPH-L710 using Tapatalk 2
CruznSS is offline   Reply With Quote
Old 01-28-2014, 07:59 AM   #4
turboguy327
Banned
Drives: 2011 Chevy Camaro
This.
turboguy327 is offline   Reply With Quote
Old 01-28-2014, 08:11 AM   #5
Eric-MPD1.com
Drives: Cool parts for cool cars
I have found that as long as you have a factory paint, as in no re-paint work, you can use lacquer thinner to take it off. Should work really well. Just find some soft rags to use and change them out often. Then you may require a buffing but at the very least a good wax job.
Please call me if you have any ?'s on proceeding in this manner. be happy to discuss.
Eric-MPD1.com is offline   Reply With Quote
Old 01-28-2014, 08:54 AM   #6
13BlackOut21
Thanks guys!
Old 01-28-2014, 08:57 AM   #7
13BlackOut21
It is factory paint. Do I need to dilute the lacquer thinner, and is there a certain kind I need to use?
Old 01-28-2014, 09:20 AM   #8
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Use the clay bar first. If that doesn't work then you can begin to get more aggressive
Old 01-28-2014, 09:21 AM   #9
cam62
Drives: 2012 IBM Vert 2SS/rs
This!
Clay bar worked for me when a body shop got overspay ALL over my car when simply painting a bumber.. sheesh. Only I know it's still in my convertible top. :(
rx catch can;vmax ported throttle body;bowtie delete;SLP SS emblem;CAI cold air intake
cam62 is offline   Reply With Quote
Old 01-28-2014, 09:22 AM   #10
Devryn17
Suffers Fools Poorly
Devryn17's Avatar
Drives: 2010 SS/RS, CGM w/ Silver Stripes.
I'll third this suggestion. If the paint had any dust on it, or was recently waxed, a little overspray should wipe right off with a claybar.
2010 2SS/RS, CGM w/ silver stripes. Hurst Shifter, long tube headers, full exhaust, CAI, tune. SAE 407 RWHP/402 RWTQ
Momma didn't bronze my shoes, but when I turned 16 I inherited a lead foot.
Devryn17 is offline   Reply With Quote
Old 01-28-2014, 09:26 AM   #11
SSTG
You won't need thinner.
Just use the clay bar and apply a coat of wax/sealant afterwards.
Old 01-28-2014, 10:10 AM   #12
13BlackOut21
Thanks guys! Ill look into the clay bar first! Every time I wash my car it goes in the garage and I wax it up! Sounds like I might have a chance!!! Thanks guys! Im starting to feel a lil better now...
Old 01-28-2014, 10:29 AM   #13
jacksoncoffeeco
Drives: 2010 Hennessey HPE650
Meguiars has a hot line that you can call and talk to experts. Free too. Go to their website, get the number and call them directly. I too believe a clay bar would work, (keep using new clay a lot because you'll be picking up paint chips) but I suggest you call the experts and see what they recommend.
jacksoncoffeeco is offline   Reply With Quote
Old 01-28-2014, 11:15 AM   #14
Eric-MPD1.com
The lacquer thinner may sound extreme to some but its faster, helps you get in all the tight areas easier. Coming from a guy who has done a lot of painting and final detailing in his life.
By all means do what you are comfortable with. With all the waxing you have done the clay bar will work great also.
