08-11-2016, 08:53 AM | #1 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
1LE Suede shifter on my 1LS
Said goodbye to my horrible plastic stock shift knob and pleather boot this morning, and swapped on the alcantara 1LE version.
Swap went easy, feels a ton better, now I'm itching to swap the steering wheel Just needed a T-25, 7mm, and trim removal tool. Took all of 15 minutes this morning to make the swap. Rotate the collar of the shift boot, and pull down. This exposes the screw for the shift knob (2012+), and using the T-25 I took out the screw and pulled the knob off. Using the trim removal tool, I popped the silver cover off and moved it to the side, exposing the four 7mm bolts/screws that remove the shift boot. Shift boot removed. Then I just reversed the process putting it back together.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
08-11-2016, 11:18 AM | #2 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
Looks good man. Get some of this stuff and spray it on a Terry towel then wipe down every now and again it'll keep it looking good too...
http://adamspolishes.com/shop/interi...y-cleaner.html
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
08-11-2016, 01:41 PM | #3 |
Awesome, thanks for the link. I have a ton of Adams stuff, but never purchased this. This, plus a soft toothbrush should keep it looking good
08-11-2016, 03:40 PM | #4 | |
I've found that the nap on the Terry towels keep the Alcantara standing nicely. No brush needed. Whenever you see a spot getting a slight sheen or it lays flat just spray that product on the towel and then vigorously rub the Alcantara with it. You'll be G2G. I find I need to do it every couple of months and I live in FL so sweaty palms happen... lol
08-11-2016, 03:46 PM | #5 |
Thanks a bunch for those tips! Will help greatly
08-11-2016, 05:43 PM | #6 |
NP man.
08-11-2016, 06:43 PM | #7 |
Drives: 2010 2SS/RS Join Date: Dec 2009
I've seen a few steering wheels on eBay for roughly 200 bucks. I bought one from a member and got it for a steal 120.00 bucks, I got a airbag for 150 and I even restitched it to orange to match the car interior thread...
Orange Krush II
08-12-2016, 07:12 AM | #8 |
Drives: 2013 2SS/RS Convertible Join Date: Jun 2015
Hey firefighter, I was looking at the 1le wheel and shifter but I was worried about the material getting bad. Does this process keep the wheel looking good too with the extra touching it gets?
I just don't want to drop 200 on a wheel and have it look like crap in a year. It's my DD Sent from my SM-N920V using Tapatalk |
08-12-2016, 08:11 AM | #9 | |
If you use a clean white towel to do the maintenance you'll be shocked every time though. Also a little goes a long way. I'm still on my original bottle of that stuff.
08-12-2016, 09:12 AM | #10 |
My GM parts guy told me that he can get me the wheel for about $180, I just need to find the correct part number because he pulls up the 4 different wheels in the system and wants my verification.
08-12-2016, 09:17 AM | #11 | |
Drives: 2015 Camaro 2SS 1LE Join Date: Aug 2015
08-12-2016, 08:36 PM | #12 |
P/N
Here is the P/N from a Stone stitched 1LE car a manual of course. Please disregard the orange I changed the color.
Orange Krush II
08-13-2016, 07:26 AM | #13 |
Awesome! Thank you very much. Gonna get one of those ordered
Sent from my BlackBerry Priv - Tapatalk
01-19-2017, 03:28 PM | #14 |
Drives: 2010 Camaro SS (RS LS3) Join Date: Dec 2015
Sorry for bumping this thread. But does the boot stitching looks like silverish color compared to the knob white stitching?
Sent from my ONEPLUS A3000 using Tapatalk |
