Old 06-04-2019, 08:04 AM   #1
SYNGSS
SYNGSS's Avatar
Drives: 2011 Camaro 2SS/RS 6 Manual
Hendrix Poly offset bushings with LPW diff cover
Anyone here using these offset bushings on LPW diff covers without problems?
I'm asking before I attempt installing them. I know LPW suggest energy suspension poly bushings.
Thanks
[Dyno Results] 684rwhp 602.84Pktq at 6600rpm. Mods: too much to list.
SYNGSS is offline   Reply With Quote
Old 06-04-2019, 11:24 AM   #2
Aries240SS
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
You should be able to use them without issue. The important part is using the offset bushings if you aren't at stock ride height so that you maintain suspension geometry keeping the axle cages lined up with the hubs so they don't bind and break on hard launch.
2011 Camaro 1SS
Whipple Supercharged street monster
Aries240SS is offline   Reply With Quote
Old 06-04-2019, 01:47 PM   #3
SYNGSS
SYNGSS's Avatar
I'm lowered 1" all around so that was the purpose of these bushing but I was not to sure if they were compatible with the LPW cover but I learned today that they are.
Thanks
Old 06-05-2019, 08:19 PM   #4
Blakester
Drives: 2010 1ss
I had zero issues with the lpw cover and Hendrix offsets during install
Blakester is offline   Reply With Quote
Old 06-05-2019, 11:28 PM   #5
SYNGSS
SYNGSS's Avatar
Awesome Thank you..
Old 06-06-2019, 08:54 PM   #6
Blakester
Drives: 2010 1ss
Just use a urethane safe grease on the sides of the bushings where they fit into their spots in the rear subframe. Not sure if that's a common thing but the diff would not go home on my first try without some lube. I used napa sil glyde.
