Old 10-14-2019, 09:11 PM   #1
Silver02ws6
Drives: 2013 2ss 1LE HCH - 500WHP
13 1LE TR6060 - Monster Twin Disc Clutch Woes
14 days into owning the new car my throwout bearing gave way causing the trans to needed pulled. Car was already heads, cam & full exhaust so I decided to upgrade and future proof.
The mechanic talked me into a Monster Twin LT1-SC which is good to 1k horsepower. I also had him do a TSW shifter as I loved the one that was in my C6Z.
Break-in was not great as expected. I ended up trading emails with Monster and the return spring had not been removed. Monster suggested I remove that and it really made it a different car. Still, a fair amount of chatter but that's expected with this clutch from what I have read.
The problem is I am experience several issues and I can't find info. I'm not sure how much of it is TR6060 common problems vs. a potential hydraulic issue or things were not installed correctly.
The issues:
*I've bled the clutch twice.
1. The clutch hangs - When turning and riding it out it will literally hang which causes the car to buck, if I dump all the way it grabs and goes. Makes turning a bit scary when in traffic and is something i have never experience with another manual car.
2. Car is getting hung in gear. Happens in 1st, 2nd 3rd and reverse. Low speeds in 1st or second it's like the car doesn't want to come immediately out of gear when I push the clutch in... if I coast a bit seems to slip right out. Will get stuck in reverse and i will have to let the clutch out to where it starts to grab and then push back in to release.
3.Car doesn't want to go into second sometimes when driving hard but from my research, this seems to be a TR6060 issue. Shift fine into all other gears.
I have no clue where to even start. The shifting is either buttery smooth or feels a bit like driving a tractor-trailer rowing through the gears. Heat in the trans has little to do with this. It happens cold / hot and in between.
Clutch has 2500 miles on it now. 1000 of that was a long highway drive.
Silver02ws6 is offline   Reply With Quote
Old 10-14-2019, 09:21 PM   #2
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I have a spec stage 2.... similar mods. I'm having the same problem getting into second at high rpm. Already had Tick rebuild the trans and upgrade to carbon blockers. It's no better... I'm getting frustrated.
2013 1le- Katech 416 short block, TSP stage 4 cam, LOD intake, cnc heads by Wegner Automotive, Nick William's 102mm T.B., Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
Clarkstar is offline   Reply With Quote
Old 10-14-2019, 09:41 PM   #3
lemontwist
lemontwist's Avatar
Drives: 2011 2SS/RS M6
lemontwist is offline   Reply With Quote
Old 10-14-2019, 09:44 PM   #4
Clarkstar
Clarkstar's Avatar
I have the tick braided line. Ideal garage master cylinder.. separate reservoir. It feels like it just doesn't flow enough fluid to quickly disengage the clutch at high rpm.
Old 10-15-2019, 09:35 AM   #5
Silver02ws6
From what ive read this is a TR6060 issue. That's actually the thing that concerns me the least based on my problems and what I've been able to find.
Old 10-15-2019, 10:08 AM   #6
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
Did you change the throw out bearing? Also how many miles on the car/trans? Lastly what fluid are you running in the trans? I'm especially interested because I'm intending to buy the LT1-S (level below yours) clutch which hopefully has more reasonable driveability.
Sent from my SM-G973U using Tapatalk
Firefighter is offline   Reply With Quote
Old 10-15-2019, 10:17 AM   #7
Silver02ws6
I did the billet throwout bearing they offer. Not sure the fluid but it was changed by the shop that did the work.
Clutch has around 2500 miles on it... trans has just over 30k.
Old 10-15-2019, 11:26 AM   #8
Firefighter
One thing maybe to suggest just to rule it out is a fluid change. For some reason these trans are sensitive to the fluid. It uses an ATF for starters and that screws with an old timers head to be sure. I personally run the Valvoline Maxlife ATF and it works well. If you're really looking to rule out any chance of fluid related weirdness Tremec recently came out with a fluid specifically for their trans Summit has it. Also make sure the clutch/brake fluid is fresh and at least DOT4.
If problems persist after that then you gotta look at the clutch again. I hope it works out.
Old 10-15-2019, 12:16 PM   #9
608RS
608RS's Avatar
Drives: 2015 2ss
interesting, is this the fluid you're speaking of?
http://www.tremec.com/not_am_detalle...mission-fluid/
2015 Camaro 2ss, NicKey Performance built/tuned
608RS is offline   Reply With Quote
Old 10-15-2019, 12:25 PM   #10
Clarkstar
Clarkstar's Avatar
I've tried mobil 1 atf, redline and now amsoil... all the same. I changed the throw out bearing and have the monster billet slave bearing support.
Old 10-15-2019, 01:05 PM   #11
Firefighter
Yeah, that's the stuff. It's expensive as hell though.
Old 10-15-2019, 01:14 PM   #12
Firefighter
I noticed the transmission was less "finicky" after I did the fluid swap to the Valvoline MaxLife ATF Synthetic fluid. I'm getting ready to swap out the fluid again I'll probably do the Tremec MTF this time.
The reason I'm suggesting the fluid swaps is to rule out the 6060 fluid quirks.
Old 10-15-2019, 02:16 PM   #13
Silver02ws6
I confirmed that Amsoil Torque Drive was used in mine. Per the research, I have done people seem to have had good luck with that fluid. Mechanic is suggesting the car needs a separate reservoir which seems like a good idea in theory.
Afraid with the sticking in gear and floating issue that the trans is going to have to come back out. The thought of that is pretty discouraging considering the cost of the clutch install the first time around.
Old 10-15-2019, 05:51 PM   #14
Firefighter
If you look around in my thread (see signature) you can see where I did two different separate reservoirs. Initially I did the GTO one and it helped but the Tilton reservoir is better. I believe I posted the template if not I might be able to locate it still. I got it from another member but it was an excellent base for the bracket I made.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
