11-25-2014, 08:54 AM | #1 |
who is running ECS 1500 and unrestricted?
Just want to see how many has tossed the disc.
11-25-2014, 09:02 AM | #2 |
Never had a restrictor on my ECS kit, and pulled many a friends. Solid 800rwhp with a good cam/meth unrestricted. Make sure you have plenty of fuel.
Nick
Corvette Z06 -1200ish rwhp |
11-25-2014, 10:54 AM | #3 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
I would if squash would ever come out with their returnless setup and i put this cam in.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
11-25-2014, 11:33 AM | #4 |
Drives: '11 Camaro Supercharged Convertible Join Date: May 2014
I had mine unrestricted. With bigger injectors, cam and meth. I was running 15 lbs. and broke into the 800 whp range.
2011 Triple Black SS convertible, LSX 427, PRC 260cc heads, Callies Ultra Billet Rods, Wiseco -20 cc piston, Callies Dragon Slayer crank, Strange Dana 60 rear w/3.73 gear ratio and driveshaft, Pfadt coilovers, Pfadt sway bars, Pfadt trailing arms, Pfadt tie rods, Pfadt subframe bushings, Vortech YSi with wastegate and twin BOV, Haltech ECU, Mantic 9000 Twin Clutch, ALKY control meth system with dual nozzle, Squash twin fuel pumps, ACS T3 ports, VIS Terminator Hood, Seibon ZL style lip.
11-25-2014, 12:45 PM | #5 |
I have plenty of fuel, Lingenfelter twins and FIC 850cc. Just seeing how many are running around unrestricted.
11-25-2014, 02:11 PM | #6 |
Drives: 2011 2SS/RS RJT Join Date: Aug 2010
Unrestricted from day 1
Running dual CTSV pumps, ID 850s and single stage meth
Todd Downing
2011 2SS/RS LS3/M6 RJT, GFX, ECS Blower, FSP Blower Cam, SW 2" headers/3" exhaust, 3.91, tuned by Fasterproms 745 rwhp, 620 rwtq 2012 Silverado 3500HD SRW Duramax/Allison, 540 rwhp, 1100 rwtq. |
11-25-2014, 02:34 PM | #7 |
I've never been restricted either but I don't have an actual ECS kit. It's more of a Paxton kit so its pullied low at first. I have been pullied 7.8 x 3.47 for a while now at 12psi so going to the 3.33 will put me at the pulley setup that the ECS kit has just no restrictor. I'm doing the 3.33 swap regardless but was just curious on how many other people are unrestricted.
11-25-2014, 04:20 PM | #8 |
The number of people running it unrestricted might be more than you think. I was at FSP today talking to Matt and he said he's done many setups similar to mine since my install nearly 2 years ago. I was his 2nd ECS install since opening FSP. It's a relatively inexpensive/safe way to make 700 - 800 RWHP (depending on the type of dyno used ) on a stock bottom end. I hope my motor doesn't go boom after saying "safe".
Todd Downing
11-25-2014, 04:24 PM | #9 |
One other thing - I believe with that pulley if you rev high enough you will actually be pushing the blower a little bit past the recommended rpm. It hasn't been an issue for me so far. My limiter is set at 6800 IIRC. I try not to hit it, but the darn thing spins up so fast it's hard to shift in time. I have a shift light on order.
Todd Downing
11-25-2014, 04:30 PM | #10 |
Non ECS Novi with no restrictor, 3.33 pulley and meth. 12psi
No cam.
11-25-2014, 04:43 PM | #11 |
You can find the blower speed limits online somewhere. Don't remember where but I looked it up before changing my pulley. At 6500 I still have a small buffer before the blower hits its max with the 3.33. I think my crank pulley is different than yours though.
I would love to add a cam but I know I will have to jump up to the id850's and swap out the zl1 pump with a dual. What I would really like to do is yank the motor and throw in a forged rotating assembly with some head work and then do the cam.
11-25-2014, 04:45 PM | #12 |
Max rpm for the 1500 is 55k so 7.8 x 3.33 is safe.
11-25-2014, 10:39 PM | #13 | |
11-26-2014, 06:20 AM | #14 | |
How do you like your 427?
