Solo Performance
Old 07-23-2018, 06:04 PM   #1
Stubbz
Drives: 2011 camaro SS
piston ring Gaps
anyone know what the factory piston ring end caps ?
Stubbz is offline   Reply With Quote
Old 07-23-2018, 06:45 PM   #2
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
What engine?
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
BMR 1" lowering springs, trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified FULLY 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Tuned by Ronnie @ RS Motors in Burnsville.
438 WHP, 406 WTQ on a Mustang Dyno
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 07-23-2018, 07:02 PM   #3
hou30guy
Drives: 2011 convertible 2ss/rs
Probably somewhere around . 024/.022
Sent from my SM-N950U using Tapatalk
hou30guy is offline   Reply With Quote
Old 07-23-2018, 08:49 PM   #4
Stubbz
6.2 ls3
Old 07-24-2018, 09:08 AM   #5
Russell James
Russell James's Avatar
Drives: two 5ths and a 1st
The LS3 ervice specs in inches from the service manual are below.
top ring .0067" - . 0173"
2nd ring .0126" - .0272"
oil control .0086" - .0335"
It's a pretty broad range, and for performance use, you certainly would not want to be near the min.
If file fit perfecting a blueprinted engine for high performance use, I'd go with something like:
1 .020"
2 .024"
oil .024"
It's on the high side, but removes the biggest problem of butting the ends together if the engine ever got hot.
Make sure to use a good ring grinding tool, the gap ends must be parallel when square in the bore. It's an all day project to perfect, and you have to sneek up on that perfect gap.
Old 07-24-2018, 10:06 AM   #6
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
intended usage plays a big part...staying N/A or going F/I or N2O? That along with piston design/style and cylinder wall finish will dictate final gap...good luck and take/share some pics or ur build...everybody luvs sum pics!
peace
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 128K! - All work by me...
Old 07-24-2018, 11:01 AM   #7
Russell James
peace
Exactly. The LS7 and LSA use slightly wider ring gaps, as those engines will see a more extreme use. The LS3 OE ring and bearing specs are pretty narrow gaps/clearances. For really high performance use, go with a tri metal bearing and the clearances opened up a bit closer to .002". Along with ring end gaps opened up a bit. Gotta get those bearing clearances and ring gaps opened up for something that would see higher loads, heat... than a grocery getter.
Old 07-24-2018, 11:42 AM   #8
Stubbz
im staying N/A with the car still using factory pistons
Old 07-24-2018, 12:05 PM   #9
hou30guy
Mines at. 028 top. 028 middle oil. 020 on my 408 stroker, maggie at 20 psi
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
