Old 09-09-2018, 08:58 AM   #1
91 zeee
Drives: 2014 SS
Is there a reason NOT to use a 1LE catch can?
Iíve been looking all over this forum at catch cans. It seems that the factory 1LEis the cleanest looking installation. Is there a reason to go with something after market instead of the 1LE? Iím leaning towards the 1LE, but with all these aftermarket options out there, Iím guessing there must be a downside?
91 zeee is offline   Reply With Quote
Old 09-09-2018, 09:51 AM   #2
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Not that I know of other than its not too pretty looking sitting on the valve cover, nice thing about it is that it is self draining! I have one on my 1LE and it works great.
zz430camaro is offline   Reply With Quote
Old 09-09-2018, 10:57 AM   #3
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
I believe what your referring too would be the clean side separator not a true catch can, and its for storing temporarily with WOT runs oil that does filter back down after coming off the pedal...… for a real set up see Elite engineering .
See the red canister on the left that looks so Unclean install...LOL that's a catch can.
You really want to see things cleaned up read the sticky "cleaning up the engine bay" from Moreno Motorsports.... up above on the engine section.
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr25% udp, LPW diff cover, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks billet badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 09-09-2018, 11:00 AM   #4
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
The 1LE catch can is for the clean side of the PCV system, are you wanting the clean or dirty side catch can. There is a difference. Just checking. The 1LE catch can is a very clean and factory looking unit, it does it’s job well.
HOJO is offline   Reply With Quote
Old 09-09-2018, 10:52 PM   #5
91 zeee
Drives: 2014 SS
That’s a good question. I’m using the car for road racing. If that is what GM used on the 1LE is it good enough? Maybe I do need both?
Old 09-10-2018, 12:17 PM   #6
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
Our billet cleanside separator is far more effective than the empty plastic GM unit with a separate coalescing chamber and can be used year round.
Cheaper than the GM unit as well:
Replaces the stock oil fill cap and you simply cap the factory barb on the inner front of the passenger side valve cover. run hose from the main intake tube to the CSS.
http://www.eliteengineeringusa.com/c...oil-separator/
Elite Engineering is offline   Reply With Quote
Old 09-10-2018, 12:17 PM   #7
Russell James
Russell James's Avatar
Drives: two 5ths and a 1st
Both is the best approach IMO. I have the 1LE, and an Elite. Many track days, on a '15 1LE SS they seem to do their job. A few table spoons of oil in the can after a track day.
Old 09-10-2018, 01:59 PM   #8
zz430camaro
Drives: 2015 1LE
Can you please tell us the advantages of one or the other, meaning the clean side separator and the other type.
Old 09-11-2018, 01:52 PM   #9
Elite Engineering
Drives: 2010 Camaro
The GM CSS is an empty plastic piece that traps by condensation, and the Elite is a billet piece made of 6061 T6 Aluminum with an internal coalescing chamber filled with stainless steel coalescing media that does a far better job of separating and preventing oil ingestion through the fresh/clean side of the PCV system. This is only responsible for app 5-15% of the total ingestion so you should run a proper foul/dirty side can to benefit.
Our E2 and E2-X dual valves will provide 90-95% effectiveness as well as full time evacuation suction VS part time for the stock system.
Most catchcans, no matter the brand name are only 15-30% effective in comparison.
Old 09-11-2018, 06:15 PM   #10
91 zeee
Drives: 2014 SS
So, need to run two then. Thank you for the explanation.
Old 09-12-2018, 10:45 AM   #11
xc_SS/RS
Drives: 2010 Camaro SS/RS
Could you explain where to place the clean-side bung on an intake? It looks like some intakes have the bung in the middle of the intake tube (stock ish location) while others put it in the silicone coupler that attaches the tube to the throttle body.
2010 2SS/RS
Z/28 intake, ported TB, vr wedge, rod-mod intake, speed engineering LT's, 3" exhaust, ATI -10% pulley, MGW shifter, 160* t-stat, HP Tuners, some suspension work, stickers and a little weight loss. 12.72 @112.36 - improvements coming
xc_SS/RS is offline   Reply With Quote
Old 09-12-2018, 05:25 PM   #12
Elite Engineering
Drives: 2010 Camaro
As long as it is post MAF so the MAF sensor meters the incoming air, unless it is a turbo or centri blower.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
